Controlling both extruders through control panel
Why is there only one extruder under the move axis menu? Should there be two? I just setup the printer and am having trouble feeding filament into the second extruder. Thanks.
Re: Controlling both extruders through control panel
I've checked the firmware of the PROC.
The menu of the PROC LCD is not correct. Maybe you can feedback it to the technical@geeetech.com
Which Marlin FW Version ?
Thierry
Thierry
(+3 x Kossel)
Mostly PLA
(+3 x Kossel)
Mostly PLA
It currently has Version 1.0.04 as updated through the easy print software.
I also loaded the firmware on the firmware page, http://www.geeetech.com/forum/viewtopic ... 20&t=17046, using arduino. It loads as version 1.0.03.
