Quality changes with height of print
Nibbo
Post by Nibbo »
Hi... I'm pretty new to 3d printing but have had quite a few success but today hit a new problem. I have tried to print a dice tower which is just below maximum possible with my I3 Pro B. Took 7 hours. The bottom/first couple of inches were fine but from then on the quality of print deteriated quickly with layers not sticking together. I let it continue and the top couple of inches are better. Not sure why the middle should be so poor. Any ideas?
I think a pic has attached OK.
Rgds
Nibbo
Re: Quality changes with height of print
Post by _kaktus_ »
Hello.
Although the printout is not a success, this tower is beautiful. :D
What kind of plastic (filament) do you use :?:
Nibbo
Post by Nibbo »
Hi Kaktus
It's 1.75mm PLA from Sunlu
Yes I'm disappointed it didn't print well. Someone gave me the printer and its the first time I've tried printing something this tall.
the tower is from https://www.thingiverse.com/thing:3333718
Post by _kaktus_ »
Hi.
I would try to raise the temperature of the hot end a little.
I noticed that up to a certain height the printout is flawless. It is possible that up to this height the printer worked the most often, and the mechanisms aligned and adapted.
Have you lubricated the Z-axis screws with oil :?:
You can also try to reduce the print speed.
Nibbo
Post by Nibbo »
Thanks for your suggestions Kaktus, I will try them.
However, I probably wont try to print the tower again because it took seven hours last time. I think I will try a different approach where the tower is printed in sections.
thanks for your help
rgds
Dave
Post by _kaktus_ »
Hi.
I forgot about one more.
When I was using poor quality filament I had various problems.
Nibbo
Post by Nibbo »
OK Kaktus - thanks
I must admit I am using a new reel of filament that someone gave me. I will check that put too.
rgds
Dave
