A10 with Marlin 1.1.8 not printing after 3dTouch upgrade
heliport23
Post by heliport23 »
Hi all guys,
I did yesterday a 3dTouch sensor to my A10 and put the new software from this side to the board. All worked fine and also bed leveling worked well. But as soon I start a print from SD card, after Autohome, automaticaly Z setup and heating of bed and nozzel there is only a bar running on the display but no moving on any axis. In this case the SD procent is runnung from 0 to 100% without any print and after the SD is on 100% the printer is going to Autohome :o :o :o .
Is there anyone there who can help?
heliport23
Re: A10 with Marlin 1.1.8 not printing after 3dTouch upgrade
No idea guys? Should I flas the A10 without 3dTouch again to check if the Firmware is the problem?
BR Harald
heliport23
Update,
I switch back to the Firmware without 3dtouch and no all worked well as before :!:
So there must be a bug at the Firmware with 3d touch :cry:
BR Harald
It seems we missed the bug.
Maybe it was the Arduino compiling error.
Alxo
Post by Alxo »
heliport23 wrote: Fri Mar 08, 2019 10:57 pm Update,
BR Harald
I had the same problem, use Arduino IDE 1.8.5 to upload the firmware you can find in the official thread (I haven't tried later versions from vert) and the printer is operational again
