Hi vert,
thank you for the information.
BR
Marlin 1.1.9 firmware for A10M (pre-built, fine-tuned, both with & without 3d touch) by aarli
Re: Marlin 1.1.9 firmware for A10M (pre-built, fine-tuned, both with & without 3d touch) by aarli
Where is the config_adv.h file in your build? cant find it anywhere on your github. Also, can you add filament runout?
put the right config... h file for your printer into the marlin directory before flashing
and enjoy
good work vert
This post has been locked.Try to use the default fw or the fw from vert.
viewtopic.php?f=92&t=68228
