Prime Tower with Cura 4.0
abp666
Post by abp666 »
Using Cura 4.0 (with A20M files incorporated). Prime Tower is enabled but it only shows up on the Cura build plate as a shadow. I suspect I'm overlooking something obvious to activate it.
Gingko
Re: Prime Tower with Cura 4.0
Post by Gingko »
1, Could you please show us a pic for it?
2, Has the model two different colours or only one colour?
abp666
Post by abp666 »
screenshot attached...model shows two colors. The prime tower is shown in shadow and appears round even though I haven't selected that option.
Appreciate your help...
Annotation 2019-04-21 175003.jpg (118.25 KiB) Viewed 11046 times
Tomyuan
Post by Tomyuan »
I think you need to click"Slice"
Click"Preview"then you will find the prime tower is in there.
abp666
Post by abp666 »
I've already sliced it and no prime tower when I tried to print.
When I use preview in layer view the lizard becomes a shadow (along with the prime tower). In X-ray view the lizard is in two (differnt) colors and the prime tower is still in shadow.
Tomyuan
Post by Tomyuan »
You can try to set the correct Prime tower position(X/Y).
If this part out of the hotbed then it won't show normal. :?
abp666
Post by abp666 »
Ok...will try...thanks
