Prusa i3
stemboy400
Prusa i3
Hi, I recently got a Prusa i3 and it works perfectly fine apart from the SD card reader. I got a 64 gig SanDisk SD card but it can't read it. When I insert it, it says card inserted but in the menu it says no SD card. It works with a 2 gig SD card. Any ideas on what to do would be appreciated.
Re: Prusa i3
Hi, maybe your SD card format does not match and can't be read.
stemboy400
Re: Prusa i3
I've tried formatting it, at the moment it's a exFat. I read that you should use a cameras formatter but it couldn't read the SD card.
Re: Prusa i3
Do you have to try to insert another SDcard, is the printer reading?
stemboy400
Re: Prusa i3
Yes, the printer can read a 2 gig card.
