Assemble the X-Z axis Problem
zhangxueyou
Re: Assemble the X-Z axis Problem
Post by zhangxueyou »
It is inside the hole.
il est dans le trou
danger_dan46819
Post by danger_dan46819 »
The threaded rods are 8mm (.311 inch in Diameter) I had to ream the holes out to .312" (5/16") so they would be round and rotate freely. Also lubricated the brass nut and the hole that was reamed. That quieted everything no more squeaking. My problem is I could not get anything to move until I moved the limit switches to the MIN pins not the MAX pin plugs.
zhangxueyou
danger_dan46819 wrote:The threaded rods are 8mm (.311 inch in Diameter) I had to ream the holes out to .312" (5/16") so they would be round and rotate freely. Also lubricated the brass nut and the hole that was reamed. That quieted everything no more squeaking. My problem is I could not get anything to move until I moved the limit switches to the MIN pins not the MAX pin plugs.
Yes, the endstops should be connected to MIN slots.
