Firmware Uploading Issues
hillwwl
Re: Firmware Uploading Issues
Post by hillwwl »
AHHHHHHHHHHHHHH!!! I'm an assumption making idiot then hahahahah. Well at least that makes a LOT of sense. My printer is the "Geeetech i3 pro C dual extruder 3D printer" (found at this link: ).
http://www.geeetech.com/geeetech-i3-pro ... niafcnpqe6
OH and I bought it on ebay if that makes a difference.
So, considering this should I just edit the marlin firmware for the P13B-ramps as according to this wiki?
http://www.geeetech.com/wiki/index.php/ ... et_Started
(I don't mind getting to play around with it a little :) )
If it's more complicated than that would you guys please email it to me, here is my email:
hillarywinchester@gmail.com
Visi
Post by Visi »
i received today the firmware (marlin) for my new Printer: Geeetech i3 pro C dual extruder with geeetech GT2560 controller (0.4 mm nozzle).
Problem are, that i get an error message and cant upload the firmware.
Here are the error message:
Arduino: 1.6.4 (Windows 8.1), Platine: "Arduino Mega or Mega 2560, ATmega2560 (Mega 2560)"
temperature.cpp: In function 'void manage_heater()':
temperature.cpp:675: error: unable to find a register to spill in class 'POINTER_REGS'
temperature.cpp:675: error: this is the insn:
(insn 98 97 100 4 (set (reg/v:SF 103 [ pid_input ])
(mem:SF (post_inc:HI (reg:HI 146 [ ivtmp.209 ])) [4 MEM[base: _110, offset: 0B]+0 S4 A8])) temperature.cpp:459 99 {*movsf}
(expr_list:REG_INC (reg:HI 146 [ ivtmp.209 ])
(nil)))
temperature.cpp:675: confused by earlier errors, bailing out
BR Visi
zhangxueyou
Post by zhangxueyou »
Visi wrote:Hello,
(nil)))
BR Visi
Hi, Visi
It is recommended to upload the firmware with arduino1.0.1:
http://arduino.googlecode.com/files/ard ... indows.zip
You can refer to this page to upload the firmware:
http://www.geeetech.com/forum/viewtopic ... 20&t=16253
hillwwl
Post by hillwwl »
IT'S RUNNING!!! Well done zhangxueyou!!!! You are the man (or woman)!!!!!! the printer is working brilliantly as is the lcd. I must say, I am quite impressed, you guys do have a great little package here! It still appears that my second extruder isn't being recognized by the lcd nor Repetier, but I'll double check my wiring and get back to you on that. Thanks SO MUCH for all of your help!
zhangxueyou
hillwwl wrote:IT'S RUNNING!!! Well done zhangxueyou!!!! You are the man (or woman)!!!!!! the printer is working brilliantly as is the lcd. I must say, I am quite impressed, you guys do have a great little package here! It still appears that my second extruder isn't being recognized by the lcd nor Repetier, but I'll double check my wiring and get back to you on that. Thanks SO MUCH for all of your help!
Open Repetier-Host 1.0.6, access "Printer Settings":
Set the amount of extruder, so that you can heat up both extruders in Repetier:
But that's not enough, if you want boths extruder work when printing, you need to have correct slicer setting:
Access "configuration" to set slicing:
You can download this file to set it:
slicer settings for I3C.zip
(740.38 KiB) Downloaded 616 times
