Page 2 of 3
Re: Printer stops randomly
Posted: Fri Jun 05, 2015 9:00 pm
by iron7
I have the A4988 stepper drives they are plug correct. I have tighten the belt, but the problem keeps. I noticed that the problem is only on X axis. Why this starts after a couple of layers and doesn't start from the beginning of the print? What other possibilities exist ?
Posted: Sat Jun 06, 2015 9:52 am
by zhangxueyou
Let's check if it's g-code issue. Please try to print with the attachment. Please raise the temperature of extruder and hot bed properly before printing.
Posted: Sat Jun 06, 2015 10:30 pm
by iron7
I printed the object, the result was satisfying. So the problem is generated from gcode ?
Posted: Mon Jun 08, 2015 9:37 am
by zhangxueyou
Let's spend more time on printing one more thing to check if it is really slicer issue, please print with the attachement. Please heat up the extruder and nozzle in advance.
Attachment is extruder holder, you'd better print in ABS if you have ABS, because the holder printed in ABS is better, you can replace it in case of the older one is broken.
Posted: Mon Jun 08, 2015 7:20 pm
by iron7
I tried to print the holder, you can see the result in the photo below. I printed with PLA because i haven't ABS, the extruder temperature was 200 C and the bed at 60 C. The problem keeps on ...
Posted: Wed Jun 10, 2015 8:47 am
by zhangxueyou
Is there any error displayed on LCD when it stops printing?
Posted: Fri Jun 12, 2015 6:43 pm
by iron7
No there are no errors, the only things that lcd displays are the temperatures and the X Y Z coordinates. I usually kill the print because is a waste of material after problem appears
Posted: Sat Jun 13, 2015 8:58 am
by zhangxueyou
Please try to print again, see if it stops at the same place. If it stops at the same place, I think it is gcode issue, maybe it was not completely copied to your SD card.
Posted: Mon Jun 15, 2015 5:54 pm
by iron7
The printer doesn't stop, i kill the print because is a waste of material, and i print online with repetier not from sd card
Posted: Tue Jun 16, 2015 9:20 am
by zhangxueyou
Please try to print with SD card, maybe it is Repetier's issue.
