Delta Rostock Mini G2 dual extruder- First startup help?
Antex_N
Re: Delta Rostock Mini G2 dual extruder- First startup help?
Post by Antex_N »
Sorry that link does not help me, says nothing about error codes like mine " fatal error: time.h: No such file or directory
#include"
And your link says noting about setting bord in Configuration.h .... are you sure im not supose to change it to bord
34? (=RAMPS 1.3 / 1.4 (Power outputs: Extruder0, Extruder1, Bed)
set Bord 7 was the stock setting (7= ultimaker)
that cant be right, or?
The problem is that thers no singel complete guide at one place only, its spred over a bunch of places and all says different...
If geeetech them selfs dont know whot the error code means then how am i supose to know whots wrong :cry:
Sherry
Post by Sherry »
hi,what's type of your main board?if it's gt2560,you should select the mega 2560 rather than ramps 1.4.please see the link.
regarding to the error : fatal error: time.h,maybe the something goes wrong when burning the firmware.please select the correct board type and port.
hope this will help you.
vmishev
Post by vmishev »
Try downloading lower version of Arduino (1.0.6 for example). It worked for me :)
Antex_N
Post by Antex_N »
well yes my main board is Gt2560 and i have select that in Tools/Bord: "Audrino Mega or Mega 2560"
I have select the correct port as well.
what I mean is: if you open the firmware you sent me in Arduino, click on the tab Configuration.h
you will see these options of Main Boards (See picture)
Main Bord
Main Bord
as I wrote earlier, 7 = ultimaker was the stock setting?
I just wonder if not 34 = RAMPS 1.3 / 1.4 (power outputs: Extruder0, Extruder1, Bed) would be a more appropriate setting because my power outports applies to this option?
Br. Andreas
sagat
Post by sagat »
Hi ,I have the same issue with compilling
qr_solve.cpp:7:18: fatal error: time.h: Adresář nebo soubor neexistuje
#include <time.h>
compilation terminated.
bkbot
Post by bkbot »
I'm having the same issue with my G2S. I jsut got is and am on Day 3 of the build. I can home the printer and trigger the X,Y,Z endstops. But when I try and calibrate the autolevel the printhead crashes into the bed. If i try to manually activate the auto level endstop nothing happens, the carriages don't stop and the printhead still crashes the bed.
I've verified that the endstop is returning the correct status using M119, it just seems like the firmware isn't doing anything with the info.
I've already updated the firmware based off another post, can you please send me the latest version. Also, the firmware version in the filenames are in Chinese, so I don't which version is the latest.
sagat
Post by sagat »
Hi , time.h erorr is caused by bad versino arduino IDE, you need older version 1.0.1
Antex_N
Post by Antex_N »
Thanks sagat, i will try 1.0.1 right away :arrow:
Antex_N
Post by Antex_N »
well i got no errors with Arduino 1.0.1 got the frimeware upploaded but now the display only shows some rundom pixels and the X motor is "switching on and off" constantly every second
can not even connect it to the computer anymore... Money well spent :evil:
Try to reburn the latest firmware here .
RKMA_GT2560_G2s.zip
(283.25 KiB) Downloaded 479 times
