Problem with PSU
kylon_982@hotmail.com
Re: Problem with PSU
220v, and yes, i tried to adjust it but, it doesnt reach higher voltage, the max i got is 9v
You measure the voltage directly or connect it to the motherboard then test?I wanna you test the DC output of PSU directly...kylon_982@hotmail.com wrote:220v, and yes, i tried to adjust it but, it doesnt reach higher voltage, the max i got is 9v
i got the psu disconnected from the board, so all measures i've done are directly from the psu output, directly from the screws of the psu
OK,i'm afraid the PSU was broken.kylon_982@hotmail.com wrote:i got the psu disconnected from the board, so all measures i've done are directly from the psu output, directly from the screws of the psu
frist thing i did after seen it was not working, i test it with an atx power suppy and everything worked ok, im just claiming a new power supply cuz this one just came bad and couldnt make a use of the machine with it
Hi,my friendkylon_982@hotmail.com wrote:frist thing i did after seen it was not working, i test it with an atx power suppy and everything worked ok, im just claiming a new power supply cuz this one just came bad and couldnt make a use of the machine with it
I think you can contact the seller for the replacement.
Regards
