Rostock 301 bugs report
bang
Re: Rostock 301 bugs report
Post by bang »
Hi,Mikael
Yes,you need reflash it.The latest version is 1.0.0.2.
Read this:
http://www.geeetech.com/forum/viewtopic ... 20&t=18167
Lami René
Post by Lami René »
The latest version is 1.0.02 !
One for all and all for one !
MikaëlV
Post by MikaëlV »
bang wrote:Hi,Mikael
Read this:
I did read that ;) - but typically version numbers go Major.Minor.Patch. When I have a "1.1.0 A", then that is higher than "1.0.0.2"?
Can you indicate what are the different versions shipped? Or what are the differences from one version to the other?
Lami René
Post by Lami René »
Bonjour,
You can find the original text into English following this original French text.
Pourquoi tout le monde répète la même erreur ?
Le numéro de la dernière version n'est pas 1.0.0.2, le bon numéro de version est 1.0.02 !
Cordialement,
L'ami René
Why does everyone repeat the same mistake?
The number of the latest version is not 1.0.0.2, the correct version number is 1.0.02!
Cordially,
Friend René
MikaëlV
Post by MikaëlV »
flintewn wrote:Same first 2 bugs as raoulito9.
M104 S0 ; turn off temperature
G28 ; home axis
M84 S0 ; hold motors
M84 S0 doesn't hold the motors for me - at least not from manual control in Repetier host - the command that does hold the motors in manual control is
M17
Lami Rene wrote: ...
M300 S1244 P500
No beep here with latest FW...
vesuvius
Post by vesuvius »
Did you solve your problem?
My end script is G28, to remove hotend from my nice print !
G 28 works, but just after, steppers switch off and the the still very hot hotend crashes into my print.
I tried the M17 command, but nothing changes.
After a successful print.
