Rostock 301 bugs report
I now have a 301 that works... average, with its new metal extruder frame kit.
I use a windows 10 64b PC, and repetier host.
I flashed it with the last new firmware (1.0.02)
These but are all linked with problems with Z command...
Bug n° 1
Erratic Z command. When i swich on my printer, if i order any move, the nozzle begins to go up, and never stops, forcing the steppers at their max, no care for endstops.
Bug n°2
I ordered a G28 (home)
G1 Zxx sometimes work, sometimes not.
Bug N°3
Scripts :
For calibration i need scripts : heris my script 1
G0 X:0 Y:0 Z:20 F2000
Well after a G28, (if not the printer crashes on the roof) the printer goes to X=0, Y=0 and... Z=0, not 20 as asked....
Bug n°3
After a succesfull print.
My end script is G28, to remove hotend from my nice print !
G 28 works, but just after, steppers swich off and the the still very hot hotend crashes into my print.
I tried the M17 command, but nothing changes.
Please, let us know on how you work to correct these problems.
Please release an open souce firmware, or help us to adapt Marlin, or repetier for example, they are very performant....
Bug n° 1
Bug n°2
Bug N°3
Scripts :
Bug n°3
Re: Rostock 301 bugs report
1.You can home all the axis before you order any move.
2.You can try moving Z axis a little after the home(G28) commend,then make some other orders.
3.About the crashing,i guess it's an issue in your slicer setting.Maybe you add a code to disable all the motors,so it must crash into the print.
PS.You can attach a snapshot about your "End G-gode".
Same first 2 bugs as raoulito9.
Attention raoulito9 dans ta configuration de slic3r (pinter settings -> Custom G-code )
M104 S0 ; turn off temperature
G28 X0 ; home X axis
M84 ; disable motors
comme tu peux le voir petit M84 fout la grouille et le G28 X0 aussi il faut le remplacer par un G28.
moi j'utilise ca :
G28 ; home axis
M84 S0 ; hold motors
as asked by raoulito9, RELEASE the source code so that we can fix the different bugs we encounters.
moi j'utilise ca :
G28 ; home axis
Hi.
As you say, there are some strange things in firmware, that could have been fixed if it was open source.
PLEASE RELEASE SOURCES OF YOUR FIRMWARE.
I was not able to configure correctly the end of a print, and had some other side effects (extruder 0 endless retracting...)
I then tried to crate a whole new printer, in repetier AND in Cura (i use Cura slicer, that gives me better results than Slic3r) and...
Added a G28 at the end
And my printer homes at the end, motors don't disable and extruder no more retract. I'm satisfied.
Something had gone wrong in my previous configurations, and seemed to be impossible to correct.
Bonjour,
Quelle est la version du firmware affiché sur votre écran LCD de l'imprimante Rostock 301 ?
Merci...
L'ami René
Merci...
L'ami René
One for all and all for one !
Merci raoulito9 !
Translation with Google =William wrote:Hi,
Hello William,Salut,
1.You peut la maison tout l'axe avant de commander tout mouvement.
2.You peut essayer de déplacer l' axe Z un peu après la commend maison (G28), puis faire quelques autres commandes.
3.About le fracas, je pense qu'il est un problème dans votre trancheuse setting.Maybe vous ajoutez un code pour désactiver tous les moteurs, il faut planter dans l'impression.
PS.You peut attacher un instantané de votre "Fin G-gode".
Everything is not translated!
For an automatic translation of Google Translator kind!
Excuse me, I use Google Translator to translate the text of the forum in French, because I'm not bilingual. Thank you for your understanding and indulgence!
For an automatic translation of Google Translator kind, it is very important to follow the correct spelling and also very important punctuation rules. For example, if you do not put a space after the end of a sentence and the beginning of another, the first word of the sentence will not be translated. Same for the sentences that begin with a letter or number followed by a period. You also need a space after the period and before the first word of the sentence, if the word is not translated! Etc. etc.
Again thank you for your understanding and indulgence!
The friend René
See: http://www.geeetech.com/forum/viewtopic ... 12&t=18336 and http://www.geeetech.com/forum/viewtopic ... 12&t=18335
Traduit par Google =William wrote:Hi,
Bonjour William,Salut,
Tout n'est pas traduit !
Pour une traduction automatique du genre Google Translator !
Excusez-moi, j'utilise Google Translator pour traduire les textes du forum en français, car je ne suis pas bilingue. Merci pour votre compréhension et votre indulgence !
Pour une traduction automatique du genre Google Translator, il est très important de respecter la bonne orthographe et aussi très important les règles de ponctuation. Par exemple, si vous ne mettez pas un espace après la fin d'une phrase et le début d'une autre, le premier mot de la phrase ne sera pas traduit. Même chose pour les phrases qui commence avec une lettre ou un chiffre suivi d'un point. Il faut aussi un espace après le point et avant le premier mot de la phrase, sinon le mot ne sera pas traduit ! Etc. etc.
Encore merci pour votre compréhension et votre indulgence !
L'ami René
Voir : http://www.geeetech.com/forum/viewtopic ... 12&t=18335 et http://www.geeetech.com/forum/viewtopic ... 12&t=18336
Bonjour,
Si votre dernière commande est G28, alors la tête d'impression est en haut au centre de la plaque d'impression et la buse pourrait dégouter sur votre pièce fraichement imprimée.
Pour cette raison, je recommande pour le script de fin d'impression et d'arrêt d'urgence les commandes suivantes :
Ligne 1 : Désactiver la température.
Ligne 2 : Positionner la tête en haut et en dehors de la zone d'impression près de l'axe Z.
Ligne 3 : Fait un bip pour annoncer la fin de ...
M104 S0
G0 X0 Y70 Z200 F2000
M300 S1244 P500
Ces lignes de G-Code devraient fonctionner, si le micrologiciel "firmware" de Geeetech n'est pas bogué ou en dehors des standards prévus par l'industrie des imprimantes 3D.
Cordialement,
L'ami René
If your last order is G28, then the print head is at the top center of the printing plate and the nozzle could drip onto your freshly printed part.
For this reason, I recommend the following commands for the print and shutdown script:
Line 1: Deactivate the temperature.
Line 2: Position the head up and out of the print area near the Z-axis.
Line 3: Beeps to announce the end of ...
M104 S0
M300 S1244 P500
These G-Code lines should work if the firmware firmware from Geeetech is not buggy or outside the standards set by the 3D printer industry.
Cordially,
Friend René
Bonjour,
M104 S0
M300 S1244 P500
Cordialement,
L'ami René
M104 S0
M300 S1244 P500
Cordially,
Friend René
Hi William,William wrote:Hi,
My LCD screen reports as Version: "Firmware 1.1.0 A" - should I reflash my SW?
Mikael
