Upgrade Firmware with easy print
Re: Upgrade Firmware with easy print
with the M201 it is not working!!!!
You go always back to the old version.
By the way, where I can find the V1.0.5 for the M201 Board?
Greetings
SSAL
Greetings
SSAL
- Contact:
Did you problem solved or is it still there? I'm willing to help as I found some good tutorials on https://upgearly.com/ .
Cheers,
Staurt.
Cheers,
Staurt.
Re:Italian Message for EasyPrint Version 1.1.7
This is the link for the my italian translate of EasyPrint version 1.1.7 message file
http:/www.pittaluga.net/it.zip
Put it on the directory C:\Program Files (x86)\EasyPrint 3D\data\translations
Re: Re:Italian Message for EasyPrint Version 1.1.7
Thanks very much!Alep wrote: Sun Jan 14, 2018 2:15 am This is the link for the my italian translate of EasyPrint version 1.1.7 message file
Is it necessary or recommended to start the Printers PSU for the firmware upgrade, too? Or is it enough to connect the USB, because the USB 5V power does already start the Arduino board. I guess, the PSU is only to power the Printer hardware like steppers and heating of bed and extruders.
[quote=BR365 post_id=83865 time=1524409435 user_id=65265]
[/quote]
Which type of printer you are writing.
The individual models have a different construction.
[/quote]
[quote=_kaktus_ post_id=83878 time=1524491076 user_id=62475]
[/quote]
[/quote]
The model is a Geeetech I3 Pro C. The firmware update didn't work with EasyPrint 1.1.7 but it worked with the old beta version of EasyPrint.
With EasyPrint 1.1.7 the new available firmware (1.0.04) was displayed, when I connect the printer, but 1.1.7 seems not to be able to download the firmware file. Therefore, the update process didn't start.
With the old beta version, the firmware is loaded successfully and the progress bar becomes green.
[/quote]
[/quote]
[quote=BR365 post_id=83895 time=1524571382 user_id=65265]
[/quote]
[/quote]
[/quote]
Same here. With EasyPrint 1.1.7 nothing happens. Do I really need to downgrade EasyPrint??
[/quote]
[/quote]
[/quote]
I just found out:
To update the firmware, I had to set the Baudrate to 256000. Otherwise the loading bar doesn´t move.
To connect to the printer, I had to set it to 250000.
Now it worked.
Now it worked.
