Problems I am having with the E180
Re: Problems I am having with the E180
rogerio53 wrote: Tue Jul 30, 2019 2:04 am Hello. I cannot pull up the lever. What tool did you use. In case the lever is stuck may I use a bit of W40?
Hi, Are you referring to the bearing being stuck? You can lubricate it with proper lubrication.
apak
Post by apak »
The original PSU is able to manage a small heated bed...
I mod the e180 to another board, since smartoo src are useless and could mod the fw from the A30 to the E180 with heated bed, so I went for the skr1.3.
Now is printing even ABS at 90ºC heated bed, and 240ºC nozzle, with the stock psu.
https://www.thingiverse.com/thing:3680288
https://thingiverse-production-new.s3.a ... 653954.jpg
PATBAT009
Post by PATBAT009 »
Hello, I am having a problem printing with my geetech e180. The problem is that when I print any piece it sticks too strongly to the base and when I try to stick it out the piece breaks. I´ve been looking for this problem on the internet but I haven´t found any soulution, do you have any idea for solving my problem?
Hi, you can try to post textured paper,
Heat when removing the model and then remove the model with a shovel.
allyree
Post by allyree »
i dont know if this has been addressed anywhere else, but i just got this printer but the bed has a very bad lateral wobble that makes it impossible to print anything. its like the rollers arent tight to the frame.
is there a fix for this?
