Color mixing software for multi-mixing printer
dtouton
Re: Color mixing software for multi-mixing printer
Post by dtouton »
The Mac version doesn't work with Catalina !
An update please
dtouton wrote: Fri Nov 15, 2019 10:21 pm The Mac version doesn't work with Catalina !
An update please
Hi, Can you open the color mix when you use this system?
Can you describe your situation specifically?
dtouton
Post by dtouton »
Catalina needs 64 bits applications, I thing it's the problem
Capture d’écran 2019-11-18 à 15.44.07.png (100.06 KiB) Viewed 31586 times
FeckDej
Post by FeckDej »
You need to run a chmod command in the terminal in order to be able to open the app.
Locked
