Extruder leaking?
APLEES
Re: Extruder leaking?
Post by APLEES »
That nozzle should be screwed right in you should not see any of the thread. Make sure you remove the filament as you will end up with it all over your threads making it harder to get in. Heat it up to 10c more than you plan to print with as stated 220 is good. Keep it heated as the heat will help you remove the gunk do not over tighten as you will shear the nozzle in half. Should be a snug fit.
WhippingBoy
Post by WhippingBoy »
Damnit I managed to break the nozzle and bent the extruder block see attached picture :-(
Can anyone point me to the spare parts i need to order?
I also notized that the fan og the left site of the extruder was on all the time, is that normal?
Check the FAQ of the A10, then you need a new nozzle.
1.Heating the hotend to 220C, clean it by yourself.
2.Replace the old one.
jupesch
Post by jupesch »
Hi, here are many Tutorials at Youtube it helped me many times.
https://www.youtube.com/results?search_ ... zle+change
Greetings jupesch
APLEES
Post by APLEES »
as for the fans inside the cage they are meant to be on all the time to keep the upper parts of the print head cool from the heater block.. you would not want your filament turning to mush before it hits the heater block and nozzle...
WhippingBoy
APLEES wrote: Sun Dec 30, 2018 8:20 am as for the fans inside the cage they are meant to be on all the time to keep the upper parts of the print head cool from the heater block.. you would not want your filament turning to mush before it hits the heater block and nozzle...
Aaaahh so its meant to be running at all time/always.
Good explanation thanks.
WhippingBoy
Re: Extruder leaking? (Solved)
New printer head in place the new one is not leaking.
I will order a spare head for next time I have to replace the nozzle..
