Hi William
I am using the firmware you posted here
http://www.geeetech.com/forum/viewtopic ... 439#p97644
I installed it using Arduino 1.8.8
The problem is the 3D Touch does not respond to g code commands. It self tests on power up but is not responding to M280 P0 S10 when sent thro Repetier Host.
I also manually modified the firmware to add the 3D Touch as instructions on the wiki page
The problem is the pins.h instructions the lines to be altered are not there they are on the ultimaker pins file is this correct ?
Any help would be appreciated.
3D touch
Re: 3D touch
Re: 3D touch
Hi William,
thanks for your reply I have tried what is shown in the video with no luck.
Can I take it that the firmware you posted for my printer is correct and its a hardware issue or is it possible its a firmware problem relating to my board.
Am I correct that the GT2560A plus board is the one with it's own 3 pin connection for 3D touch.
My board required the removal of the 2 pin Z max and replaced with a 3 pin.
Cheers
Cheers
Re: 3D touch
Hi, You can try to insert the 3pin into the three-pin connection next to the motherboard fan.
