Page 2 of 2
Re: Layer shifting
Posted: Mon Sep 28, 2020 9:09 pm
by Aqua27
Hi, just received my A30T this WE.
I faced the same issue while printing the 3Dbenchy boat.
After many tests, I found that reducing the speed to 80% using the printer panel (during the printing) has solved the issue.
It seems the acceleration is too fast.
I will check to reduce only the acceleration to not have to much impact on the printing time, but also to have a permanent fix.
Hop that can help.
Re: Layer shifting
Posted: Sat Mar 13, 2021 8:58 am
by Dynamickx
Solved my layer shifting problem by repacing both the X- and Y axes stepper motors with S42B closed-loop stepper motors (and installed a smoother on both axes while I was at it). Never seen any shifted layer anymore.
Cheers!
Re: Layer shifting
Posted: Wed Apr 28, 2021 9:08 pm
by mlauber
Can you share a link to these motors?
Re: Layer shifting
Posted: Wed May 12, 2021 1:09 am
by Flapjack
Dynamickx wrote: Sat Mar 13, 2021 8:58 am Solved my layer shifting problem by repacing both the X- and Y axes stepper motors with S42B closed-loop stepper motors (and installed a smoother on both axes while I was at it). Never seen any shifted layer anymore.
Cheers!
As Mlauber says, please can you share a link for these steppers.
I'm having problems with my A30T Y axis.
Re: Layer shifting
Posted: Sat May 15, 2021 10:20 pm
by mlauber
Cheers!
I ordered some s42b V2 but when I installed them my machine started freaking out. Installed on the y-axis and the z-axis motors all the sudden start acting independently and grinding and all this other stuff. Did you change anything in your firmware to make these things work? Any help you can provide would be appreciated
Re: Layer shifting
Posted: Mon May 17, 2021 2:49 pm
by Admin
Hello, everyone, if the motherboard of your machine cannot replace the driver, you can try the following Cura configuration file to see if the layer shift phenomenon still occurs.
