Z Axis Endstop doesn‘t stop movement
nicoch
Re: Z Axis Endstop doesn‘t stop movement
Post by nicoch »
A20T
Hi,I think you should first check whether the stopper is completely normal, you can refer to:
http://geeetech.com/forum/viewtopic.php?f=17&t=60927
nicoch
Post by nicoch »
so, yes, this seem to be the problem. it's state is open all the time.
But I can't find the end stop for the A20T on the Geeetech page. They only sell the bigger red one. Where can I find this part ?
nicoch
Post by nicoch »
actually the problem is even more strange.
I switched places of the end stop switch with the one of the Y axis. It turned out to work fine.
Then I switched the Y Axis end stop board-connection with the Z Axis end stop board-connection. It turned out that then the Y axis is lit all the time and doesn't trigger anymore. The problem seem to be on the board.
nicoch
Post by nicoch »
The problem seems to be a faulty pin. Where can I find the h-Files for the firmware ?
Hi, do you mean that after the good stop is replaced, the Z-axis still cannot stop?
nicoch
Post by nicoch »
yes exactly.
Hi,try to remove the limit switch, it may be that the limit switch has prevented the 3Dtouch from reaching the leveled position.
