Z Axis Endstop doesn‘t stop movement
My Z axis endstop doesn‘t stop the z axis movement towards home anymore. If I home it I get a loud rattling noise. What are possible issues to look at and what codes are useful for debugging and posting the results here? Thanks!
Re: Z Axis Endstop doesn‘t stop movement
Hi,myfriend.
Can't z-axis stop?can you provide videos?
Now it is different. The other axis seem to have problems too now.
https://streamable.com/mbipcr
The noise was the same for the Z axis, when using G28 command. When I used Simplyfy3D's JogMode to bring z to 0 there was no problems.
Sorry, I can't open this link. You can upload compressed video files.
here we go
- IMG_0875.MOV.zip
- (11.26 MiB) Downloaded 527 times
Hi,Is this 3D touch?
It may be that the wiring of the limit switch is not connected properly. You can check it.
yes, it is 3D Touch and wiring seems okay.
Hi,according to the video you provided, the sound sounds like a limit switch failure.
You can check whether a lower limit switch lights up. If it doesn't, you need to replace it.
or you can provide a picrure of Z-axis and y-axis.
It is lit. It is red all the time and when something triggers it it gets a brighter red.
Hi,what is the model?please
