SIM900 - No registration to network
Lemon
Re: SIM900 - No registration to network
Post by Lemon »
hotkebab99 wrote:Hi,
First, not sure that 0ohm is normal for the antenna... How can it work if it is 0 ohm ?...
Second, concerning the frequency band, please read my first post, I have already tested what you say....
Here is another strange thing :
AT+CBAND?
+CBAND: INVALID_BAND_MODE,ALL_BAND
I think INVALID_BAND_MODE is not normal. I have tried to force the band with all possible values but the shiels doesn't connect to any network. More, everytime I start the shield, INVALID_BAND_MODE come back...
Thanks for your help even if I am not satisfied with the quality of this product...
Dear friend,
I have sent the information and solutions to you via my personal e-mail.
Best regards.
texouille
Post by texouille »
as far as i can see, not real solution was found for this module in order to work.
As you said onto your last post, you sent a workig solution,
can you share it with us?
Regards,
hotkebab99
Post by hotkebab99 »
I have upgraded the firmware as you said to version 1137B03SIM900M64_ST_ENHANCE
. The firmware is upgraded but it doesn't work...
Here is the result of some AT commands :
AT
OK
AT+CSQ
+CSQ: 0,0
OK
AT+GSV
SIMCOM_Ltd
SIMCOM_SIM900
Revision:1137B03SIM900M64_ST_ENHANCE
AT+COPS=?
+COPS: ,,(0,1,4),(0,2)
OK
So the upgrade of the firmware doesn't solve the problem. The shield is not working.
Lemon
Post by Lemon »
Dear All,
One of our customer shared his experience with the GSM/GPRS Shield on our forum, could you please see whether can solve your problems or not?
This is the link:
http://www.geeetech.com/forum/viewtopic.php?f=9&t=15861
Wish all of you a nice day.
Best regards.
hotkebab99
My shield is working now !
The antenna connector was not soldered properly. I made some soldering work on my shield and it works now ! :) I am registered to the network and I can send/receive some SMS.
Here is the problem !
See the picture included in this message.
kleofr
Post by kleofr »
Hi !
What exactly did you do to fix the problem? Am having the same problem.
hotkebab99
Hi.
To solve the problem, I unsoldered on the antenna socket. Quite difficult but possible.
After, I soldered 2 wires : one on the SIM900 pin and the other on the PCB where the antenna was (on one side of the socket).
Next, I soldered these wire to the antenna cable : the SIM900 pin to the interior and the other to the exterior. Look at the picture just before !
I hope it will help you !
kleofr
Post by kleofr »
Thank you,
After some research and an answer from simcom.... the IC that i have (sim900A) is locked to chinese networks only. That's why i cannot register to any EU network. I was told that i need the sim900 (quad) or the sim900R (dual).
Anyway, i ordered a different board with a "Quectel" IC
Kralj1
Post by Kralj1 »
I have the same problem(no registration or very unstable with low signal) with some of my Geetech sim900 modules.... I did the same thing like hotkebab99 describes few posts back... success.... it is working now.... Looks like this module have some problems with antenna connector...
briceagcosmin
Post by briceagcosmin »
Hello everyone,
I've encountered the same problem as you .More exactly,I've designed a PCB for my diploma project which involves a GSM module . The design is according to the GSM datasheet. Besides the problem with the network registration, there is a short between the RF_ANT pin and the ground. Should be there such a situation?
I have to mention that the pcb was tested with the ERC rules . After that the manufacturer has tested too . So, I'm at a loss what to do. I've attached my project below in hope you understand more than I said.
Best Regards,
Bebe-Cosmin Briceag
