Problem reading temperature Rambo Board
- techsupport
- Site Admin
Re: Problem reading temperature Rambo Board
you can test the r32 r37 r28 r39 is solded well。the min temp err means that the thermistors is not connected well with mega2560.it is open circuit。
Email: forum@geeetech.com
I'm not expert in dmd soldering, I've only tested all the resistors with the multimeter and always got around 4.3 k value
- techsupport
- Site Admin
Please see the attached figure,You provide resistance value is normal,
You can check the electronic circuit is normal? waiting your reply.
Best regards
Best regards
- Rambo-T0.T1.rar
- (9.56 KiB) Downloaded 580 times
To much complicated for me…
between T0 pins I have around 9 k ohm, the same on T1
cannot test further
cannot test further
