Printer dead? (Acrylic Geeetech I3 pro B)
3d Printer Noob
Re: Printer dead? (Acrylic Geeetech I3 pro B)
Post by 3d Printer Noob »
Image of switch - connections are good.
2015-04-13 07.29.49.jpg (600.22 KiB) Viewed 11352 times
zhangxueyou
Post by zhangxueyou »
3d Printer Noob wrote:Image of switch - connections are good.
Please contact customer service.
cazuroweste
Post by cazuroweste »
I have the exact same problem now. A couple weeks ago i received my replacement sanguinololu, after it was determined the z axis was shot, and then put it back together with new z axis threaded rods. I fired it up, leveled the bed, and started printing. 25minutes into the print, the green led went off, then just glowed while it was plugged into the pc. Everything else stopped. There is no voltage coming off the power supply at all. It seems this printer is plagued with problems.
zhangxueyou
cazuroweste wrote:I have the exact same problem now. A couple weeks ago i received my replacement sanguinololu, after it was determined the z axis was shot, and then put it back together with new z axis threaded rods. I fired it up, leveled the bed, and started printing. 25minutes into the print, the green led went off, then just glowed while it was plugged into the pc. Everything else stopped. There is no voltage coming off the power supply at all. It seems this printer is plagued with problems.
You said you plug your printer into pc when it's printing? Ofcourse that will stop the printing.
cazuroweste
It's always plugged into the usb, that's how repetier runs and sends the code.
zhangxueyou
cazuroweste wrote:It's always plugged into the usb, that's how repetier runs and sends the code.
How about printing off line by SD card?
cazuroweste
Won't turn on at all. The power supply is dead.
zhangxueyou
Can you get 2 groups of 12V out put voltage from power supply?
cazuroweste
No output from the power supply. Multimeter confirms it is not working.
zhangxueyou
cazuroweste wrote:No output from the power supply. Multimeter confirms it is not working.
It seems dead, if wiring is correct.
