Page 3 of 3
Re: Flashing GT2560 v3 Bootloader
Posted: Mon Nov 18, 2019 5:36 am
by boxhi
Hello
My motherboard does not boot anymore.I have an A10M.
Have a UNO attached
Unfortunately, these pins do not work for me.
my lcd board is slightly different
my A10M
- IMG_20191116_230217.jpg (348.6 KiB) Viewed 8251 times
Here is the picture of William
Posted: Thu Nov 21, 2019 7:28 pm
by boxhi
Hello
I order now a FFC 40Pin pinout board. Let's see if I can connect then.
Posted: Sun Dec 01, 2019 10:31 pm
by Skip
Well that's kind of frustrating the they change the board but still mark it v1!!
I'm having the same issue. Were you successful in programing using the cable?
Ordering my uno tommorrow for Cyber Monday, good luck!!
Posted: Sun May 03, 2020 4:16 pm
by Bernardcollin
I have the same error and I have not seen any resolution
any idea what can be done now?
Arduino: 1.8.13 Hourly Build 2020/03/09 12:12 (Mac OS X), Board: "Arduino Mega or Mega 2560, ATmega2560 (Mega 2560)"
Error while burning bootloader.
avrdude: Yikes! Invalid device signature.
Double check connections and try again, or use -F to override
this check.
option enabled in File -> Preferences.
Posted: Wed May 06, 2020 8:52 pm
by Bernardcollin
I have done some research to find a better and easier way to burn the bootloader.
The idea is to disconnect the cable to the LCD and use it to connect to the board directly from the Arduino
So here is my solution with loads of pictures
https://3dprinting.odoo.com/burn-a-bootloader-1
bernard
Posted: Wed May 06, 2020 10:40 pm
by Bernardcollin
this error definitely is a wiring issue
if you want to get the wiring sorted out easily, check my documentation
