Hard point on z axi
Briciou62500
Re: Hard point on z axi
Post by Briciou62500 »
Look the screw.
OH, if the one shown now is the same as the one you provided, you need to fix it.
Briciou62500
What should I fix, I do not understand well? :) In the photo, the 2 new support (front and back) are installed, they are new. In fact I have the impression that the hole of the support falls before the hole of the wheel the support should I think to come more to the right. But that can not be solved if the geeetech A30?
:D Installation location you can refer to:
Briciou62500
My screw is more longer. No ?
Hi,Do you remember how you removed it?
You need to fix it with a screw.
Briciou62500
No, I thought the bearing screws were all the same size.
:D Oh,Can it be fixed now?
I am not very clear about what you mean.
Briciou62500
I'm at work, 1 hour from home :)
Tonight, I'll see to redo pictures for you to understand better.
