Locked
Frejlev
Post by Frejlev »
Do you have a firmware for a rumba board? the printer is an I3 with triple extruder
Olimatou
Marlin 1.1.4 With 3DTouch / BLTouch for i3 Pro B
Post by Olimatou »
Hi folks,
Configured Marlin 1.1.4 (latest to date) to work with Geeetech Prusa i3 Pro B, 3DTouch probe mounted... Comment probe section in Configuration.h if you don't need BLTouch...
You will need to only adjust Z offset corresponding to your printer after flashing firmware from Arduino IDE to get your probe adjusted.
Issue G-Code : M851 Z[My offset like -1.4 for ex.] followed by M500 to save in EEPROM... I recommend to test and print some lines to really adjust correctly and definitively the offset between the hot-end and the probe (mounted with printed part from Geeetech)...
When using Cura, here are my starting G-Code sequence :
M851 Z-1.67 ; Set Z Offset (tuned for auto-leveling) <-- I can adjust Z-Offset on the fly here
M500 ; Store in EEPROM for future uses
G21 ; set units to millimeters
G90 ; use absolute positioning
M82 ; absolute extrusion mode
M104 S{material_print_temperature} ; set extruder temp
M140 S{material_bed_temperature} ; set bed temp
M190 S{material_bed_temperature} ; wait for bed temp
M109 S{material_print_temperature} ; wait for extruder temp
G28 ; home all
G29 ; AutoLevel 3DTouch (BLTouch)
G1 X0 F12000.0 ; Set X
G1 Y0.0 F12000.0 ; go outside print area
G1 Z0 F12000.0 ; Reach Bed
G92 E0.0 ; reset extruder distance position
G1 X60.0 E8.0 F1000.0 ; intro line <-- Print line to clean the hot-end
G1 X100.0 E18.5 F1000.0 ; intro line <-- Finish print line to clean and feed the hot-end
Avoid use of G28 after G29 command or your leveling values will be resetted...
I Corrected source code to avoid errors, so working with latest Arduino IDE 1.8.3... Here it is :
Marlin-1.1.x.rar
Marlin 1.1.4 for Geetech i3 Pro B (With 3DTouch)
(1.75 MiB) Downloaded 874 times
N.B. : SOURCE CODE IS CONFIGURED FOR LATEST GT2560 Rev A+ Board (the one with direct 3 pins probe connectors on the board). If you are using older boards with soldered probe, revert #define SERVO0_PIN variable to 32 in code...
I don't use languages other than English because LCD screen only support JAPANESE extended characters and accents are not well supported.
MP me if you encounter any bug...
EDIT : POSTED A THREAD HERE FOR THIS FIRMWARE : http://www.geeetech.com/forum/viewtopic ... 20&t=19846
Enjoy...
BalintHUN
Post by BalintHUN »
Hi Olimatou!
I don't want to be unthankful but can you provide us a non-protected .rar file of Marlin 1.1.4 with i3 Pro B with 3DTouch? :roll:
Mahai
Post by Mahai »
Hi All,
I would like to upgrade the firmware for my Me Creator 2 to the newest Marlin V1.1.4
I got it from Github and started to setup the configuration.h file.
What motherboard should I select? (#define MOTHERBOARD ???)
In boards.h the Me Creator 2 is not listed.
Please help.
Regards Mahai
Olimatou
Post by Olimatou »
BalintHUN wrote: Mon Jul 17, 2017 4:21 am Hi Olimatou!
Don't want to annoy you, mate, but this is an already unprotected rar archive... Try the good program to unpack it ^^
Wrote a thread for it here : http://www.geeetech.com/forum/viewtopic ... 20&t=19846
In zip format for the bad guy ^^
Marlin-1.1.x.zip
(2.1 MiB) Downloaded 934 times
Regards.
ChrisP28
Post by ChrisP28 »
Hi I'm extremely new to 3D printing and this is my first attempt at building a machine. I bought a Geeetech Delta Rostock Mini G2S pro With dual heads, Self levelling and heated bed With the metal extruder frame. The build went really well and the machine looks fine However I cannot get the firmware to load and the machine to work. I've looked on the forum here to find the correct firmware to try but to be honest I don't know which is the correct one to try. All I know is that I have a GT2560 mother board. Could somebody help please or recommend someone in the south east of englannd where I can take the machine for some help in getting it going.
Many thanks for your help.
You can try this firmware to your printer.
http://www.geeetech.com/forum/download/file.php?id=1560
Mahai
Post by Mahai »
Hi William,
Or is there another way to upgrade?
Please help.
Regards Mahai
The motherboard of Mecreator2 is GT2560 Rev B,you can as well update the firmware via Easyprint.
Mahai
Post by Mahai »
William,
which Marlin version will I get, if I update via EasyPrint?
Locked
