Locked
--Hi guys, all the firmware for geeetech 3D printers are here,
please choose your printer type download it, tks!
Note: if you don't know how to install the firmware, come here:
1. For board GT2560 and sanguinololu:
http://www.geeetech.com/forum/viewtopic ... 13&t=17181
2.For the board GTM32 (prusa I3 M201), please come to here install the firmware:
Using ST-link: http://www.geeetech.com/forum/viewtopic ... 13&t=17173
Using USB port: http://www.geeetech.com/forum/viewtopic ... 20&t=17597
3.If your board is GTM32 pro with 3 in 1 hotend, come here to install the firmware:
http://www.geeetech.com/forum/viewtopic ... 20&t=18167
4. If your board is GTM32 PRO VB, check out this link:
http://www.geeetech.com/forum/viewtopic ... 20&t=60425
5. If one of your axis direction is reversed, check out this link:
http://www.geeetech.com/forum/viewtopic ... 17&t=17037
6. After installing the firmware, if the LCD is beeping all the time and has two rows of blocks, then you must have installed the wrong firmware, please check it agian!
Note:
Check the threaded rod of your printer(Especially I3 PRO X, I3 PRO W, I3 PRO B, I3 PRO C)
If your printer working with T8 threaded rod
You need to send Gcode"M92 Z400" via USB port.(When you upload the firmware finished)
Then you need to send Gcode"M500" to save the setting.
1) Firmware for Prusa I3 M201
For the new board(GTM32 Pro VB)on M201:
M201_V1.0.01.rar
(58.24 KiB) Downloaded 12208 times
gtm32_machine_m201.zip
(62.23 KiB) Downloaded 14827 times
The latest version(for GTM32) :
GTM32_V1.0.5.zip
GTM32_V1.0.5
(98.94 KiB) Downloaded 19194 times
Note:
V1.0.5 added some G-code commands on the base of V1.0.4:
M92: Set axis_steps_per_unit
M110: Set Current Line Number M500
M502: Revert to the default "factory settings."
M300: Play beep sound
M304: Set PID parameters - Bed
V1.0.4 has fixed some bugs and the pause problem in the old ones, check out this link for more details:
http://www.geeetech.com/forum/viewtopic ... 20&t=17279
The old version:
GTM32_V1.0.4.zip
GTM32_V1.0.4
(97.15 KiB) Downloaded 12778 times
GTM32_1.0.3.zip
GTM32_V1.0.3
(96.01 KiB) Downloaded 11860 times
GTM32-V1.0.0.zip
(96.05 KiB) Downloaded 11275 times
GTM32-old.zip
(92.53 KiB) Downloaded 11328 times
2) Firmware for Prusa I3 X (GT2560)
I3_pro_X.zip
(295.69 KiB) Downloaded 41525 times
if you have upgrade your pro X into a dual extruder, please use this firmware
Marlin-PI3_Pro_X2.zip
(299.37 KiB) Downloaded 18926 times
3) Firmware for Aluminum I3
For sanguinololu, you need to copy the folder named "sanguino" to the folder "hardware" of Arduino IDE.
The "sanguino" folder:
sanguino.zip
(209.25 KiB) Downloaded 13409 times
Download this file and unzip it and move it to the folder "hardware".
1 for sanguinololy.jpg (34.93 KiB) Viewed 1985673 times
Then you can use the Arduino IDE 1.0.1 to upload the firmware as the link:
http://www.geeetech.com/forum/viewtopic ... 20&t=16433
For the old aluminum i3(with printed extruder bracket and gear), use the firmware below:
aluminum I3 Ramps 1.4
PI3_Ramps14固件.rar
(199.43 KiB) Downloaded 12834 times
aluminum I3 sanguinololu
PI3_Sanguinololu固件.rar
(229.44 KiB) Downloaded 13152 times
For the full aluminum I3, use the firmware here:
for the upgraded kit using lead screw aluminum I3 Ramps 1.4
Prusa I3A 2560.zip
(281.17 KiB) Downloaded 15074 times
Plusa I3 A sanguinololu.zip
(242.28 KiB) Downloaded 14622 times
4) For prusa I3 A Pro with the 3-in-1 3D printer control box:
PI3A Pro.zip
prusa I3 A Pro
(375.46 KiB) Downloaded 14530 times
for the upgraded kit using lead screw:
PI3A Pro(for the upgraded kit using lead screw).zip
(375.46 KiB) Downloaded 14617 times
if you upgrade your prusa I3 A Pro with dual extruder, please download the firmware here.
PI3A_Pro2.zip
(375.73 KiB) Downloaded 11542 times
PI3A Pro2(for the upgraded kit using lead screw).zip
(375.73 KiB) Downloaded 11260 times
5) Firmware for I3 pro&proB
I3 pro&proB(GT2560)
Marlin-PI3_Pro_B.zip
(299.2 KiB) Downloaded 67591 times
I3 pro&proB(ramps)
PI3B-ramps.rar
PI3B-ramps
(229.7 KiB) Downloaded 19727 times
I3 pro&proB(sanguinololu)
PI3B-Sanguino.rar
PI3B-sanguinololu
(229.88 KiB) Downloaded 16693 times
Marlin-PI3_Pro_B_3DTouch.zip
(314.85 KiB) Downloaded 15583 times
Marlin-PI3_Pro_B_3DTouch (A+).zip
(324.69 KiB) Downloaded 18897 times
6) Firmware for I3 pro C
Update:
Fixed the endstop error(Default endstop logic status is the"false")
2019/2/27
Marlin 1.1.8 for proC with GT2560VA/A+/2.0
1.Inculde 3dtouch config and no 3dtouch cofing
2.Added the new menu for extruder+hotend
Getech i3 pro C (Marlin 1.1.8 for all).zip
(2.64 MiB) Downloaded 13270 times
I3 pro C (GT2560)
Marlin_GT2560-PI3_Pro_C.zip
(299.21 KiB) Downloaded 28686 times
I3 pro C (ramps)
PI3B-Ramp14-2E.rar
PI3B-Ramp14-2E.rar
(268.97 KiB) Downloaded 13456 times
I3 pro C (GT2560 A+)
I3proC ( A+ board ).zip
(311.94 KiB) Downloaded 12051 times
I3proC (3d touch).zip
(321.01 KiB) Downloaded 10909 times
I3proC (3d touch A+ board).zip
(322.54 KiB) Downloaded 11679 times
7) Frimware for Delta G2/G2S
For plastic G2/G2S with printed plastic spider and carriages:
RKMA_GT2560_G2.zip
RKMA_GT2560_G2.zip
(283.11 KiB) Downloaded 11589 times
RKMA_GT2560_G2s.zip
(372.37 KiB) Downloaded 12044 times
For metal G2 pro/G2S pro with upgraded metal spider:
RKMB_GT2560_G2.zip
RKMB_GT2560_G2(pro).zip
(372.1 KiB) Downloaded 12274 times
RKMB_GT2560_G2S.zip
RKMB_GT2560_G2S(pro).zip
(372.37 KiB) Downloaded 14767 times
Note:
1. If you run into the problem that the G2S extruder2 drives axial motors when printing, you can try to solve it by reinstall the latest firmware above, and change some setting here: http://www.geeetech.com/forum/viewtopic ... 13&t=17064
2. The probe endstop, if you use the old firmwrare for plastic G2/G2S, X Y Z should connected to pin1 and pin3; and the new firmware for metal G2 pro/G2S pro, it should be pin1 and pin2 , the same with X Y Z endstops, you can refer to the link here:
http://www.geeetech.com/forum/viewtopic ... 619#p27619
8) Frimware for Me ducer
MD1_Sanguino.rar
MD1_Sanguino.rar
(268.83 KiB) Downloaded 11088 times
9) Frimware for Me creator
Me creator(ramps1.4)
ramps14.rar
ramps14.rar
(229.05 KiB) Downloaded 11770 times
Me creator(sanguinololu)
Sanguino.rar
Sanguino.rar
(229.11 KiB) Downloaded 12346 times
10) Firmware for MeCreator2(GT2560 Rev B)
MeCreator2固件.zip
(293.54 KiB) Downloaded 15113 times
Update:new version of mecreator2
(fixed the print area not correct)
MeCreator2-1.0.4.zip
(305.39 KiB) Downloaded 11414 times
11) Firmware for Rostock 301(GTM32 Pro)
The latest version(Max extruder temp 220℃):
Rostock301_V1.0.03.zip
(63.71 KiB) Downloaded 11676 times
The firmware(Max extruder temp 270℃)
gtm32_machine_delta.zip
(64.11 KiB) Downloaded 11214 times
The old version:
Rostock301_V1.0.02.zip
(63.58 KiB) Downloaded 13445 times
gtm32_machine_delta_V1.0.01.zip
(63.6 KiB) Downloaded 12380 times
12) Firmware for Duplicator 5
Duplicator5.zip
(285.92 KiB) Downloaded 10517 times
13) Firmware for Pro W
ProW.zip
(299.49 KiB) Downloaded 21855 times
update:Firmware for PROW+3Dtouch
I3 ProW GT2560A+ with 3dtouch.zip
(292.26 KiB) Downloaded 13261 times
14) Firmware for A10/A10M/A20/A20M
Note:
Fixed the bug of homing speed too fast when the printer work with 3dtouch
2018.12.27
Increase the value of Estep from the default 340 to 430(For A10M and A20M)
2018.1.9
Note:
I. Please use Arduino 1.8.5 to finish the upload
II. The firmware includes these:
-configuration.h for 3dtouch
-configuration.h for no 3dtouch
You can find it on"Configuration and hex file",choose the correct configuration.h and replace the old one.
III.Enabled "babystep Z"
Click LCD>Click"Info screen",then you can adjust it.
IV.Improved the LCD use experience
V.Improved the mixer color function, easier to use(A10M/A20M)
1.Geeetech A10 with GT2560VB board
A10_marlin_VB 1.1.8.zip
(2.69 MiB) Downloaded 11676 times
2.Geeetech A10 with GT2560V3 board
A10_marlin1.1.8.zip
(2.65 MiB) Downloaded 14641 times
3.Geeetech A10M
A10M_marlin1.1.8.zip
(2.69 MiB) Downloaded 13828 times
4.Geeetech A20 with LCD12864
A20_Marlin-1.1.x12864.zip
(1.18 MiB) Downloaded 11330 times
5.Geeetech A20M with LCD12864
A20M_Marlin-1.1.x12864.zip
(2.33 MiB) Downloaded 16701 times
You can find more info on Github:
https://github.com/Geeetech3D/Prusa_I3_3Dprinter
15) For E180/D200/A30
Please refer to this post and upload the correct firmware
http://www.geeetech.com/forum/viewtopic ... 222#p82222
mava70
Re: firmware for geeeteh 3D printers
Post by mava70 »
hello in PI3B-ramps.rar there is not Marlin.ino how to compile?
thanks
You can use Ctrl+A to select all the files and drag all of them to the arduino as the link here shows:
rmrodrigues
Post by rmrodrigues »
How I know that a new version of firmware is available?
Cheers,
RMRodrigues
We'll keep all of them updated, and if a new version is available we'll let you know too, tks!
mava70
Post by mava70 »
is it possibile to update Marlin firmware downloading it from github and allineate config.h from your config and new Marlin firmware? Did you do some kind of code personalization in you firmware outside of config.h?
I am interested in RAMPS version.
Marco
you can do it as you said but note that the marlin version shoud be the same.
azzraell
Post by azzraell »
Hi, iam very new at 3d printing, do i have to download the Ramps file and the Marlin file? or which one do i need? I have the Prusa I3 pro B, and the board is the GT2560, but iam kind of lost, not sure what to do. thanks for the help!
your printer is I3 pro B with GT2560, then just download this one:
azzraell
Post by azzraell »
Thanks alot, i have a new problem now, the printer wont home on Y axis, it does ok in the x and z axis, but wont work on the Y, any ideas why wont work? what can i do? thanks!
Locked
