Newly updated Firmware V1.0.5 for Prusa I3 M201
Re: Newly updated Firmware V1.0.4 for Prusa I3 M201
yeah you can post the gcode here and also the stl files, I'll try it later. And are the drivers get too hot after a 7hour job? I wonder if it is the printer works too long that caused this?
Malaka
Post by Malaka »
Anyone know if the new v1.0.4 fixed the long print(1,000,000) Line+1 issue? I haven't loaded the firmware yet, but I wanna know if it will fix this issue before I have to move the printer for update.
ric chin
Post by ric chin »
I give up....loaded the new firmware 1.0.4....I can manually control it....but now it won't print at all. just sits there with the filament oozing out of it...in the home position..give it a false okay.. nothing...this is worse than the 1.0.3 version for me...now I have to find what worked before...dam it.
ric chin
Post by ric chin »
On the M201 printer...there is a annoying process that it does before printing, that doesn't occur on the Pro C...it runs through the entire code before it prints....on the Pro C...I load the G code...and it prints...then echoes back what its doing...with the M201...the entire code is echoed in the log before it does anything...you never know if its going to print or not...then you have to click on the "okay" button, some times it starts printing, sometimes not and when I say "printing" it goes through all the motions except extrude, the fan on the extruder motor turns off as it attempts to extrude but no extrusion.....annoying.
dandantas
Re: Newly updated Firmware V1.0.5 for Prusa I3 M201
Post by dandantas »
hello all
i get my new gtm32 board, i tried to place my drv8825 at 1/32 steps.
i can move my axis from my ldc or from repetier.
when performe homing comand it blocks until i rset it.
in http://www.geeetech.com/forum/viewtopic ... m32#p30604
Mark says "Can not use 8825 on the GTM32 board cause the homing function is not working, but you can control it with manual control, will fix it later" it was on 26Apr2016 .
so what is necessary to help solve this problem? some of us are developers so we can help coding.
thanks
syossi2
Post by syossi2 »
helow
is there new FW comooing soon?
to enable the rest of the ports that in the boead of m2101 ver b ?
yossi
printing 3D with M201 Geeetech
syossi2 wrote:helow
yossi
Hi,yossi
Yes,it is coming soon!Plz wait patiently. ;)
syossi2
Post by syossi2 »
hi
thanks
the new fw will supprt the
3 ports: thermistor T2 , nozzle 2, extruder 2 ?
thanks
yossi
syossi2 wrote:hi
thanks
thanks
yossi
Sorry to tell you that i talked to our engineer just now,he said we have no the plan temporarily. :cry:
syossi2
Post by syossi2 »
but he promise me that he will do it
i bougt this printer becuse of that
please tell him that i have to use the 3 ports thermistor T2 , nozzle 2, extruder 2
i willing to pay him extra mouny for this jobs
thanks
yossi
