A10 auto level sensor
zonalimitatore
Re: A10 auto level sensor
Post by zonalimitatore »
vert wrote: Mon Dec 17, 2018 2:50 am
zonalimitatore wrote: Mon Dec 17, 2018 2:49 am
vert wrote: Mon Dec 17, 2018 2:46 am did you add g29 to your slicer to do auto bed levelling?
Yes,but I have no control on LCD menu,and I cannot do a Z home,cause don't detect when probe touch the bed,and continue fall down
sounds like firmware is written wrong.
I'm not the only one have this problem
zonalimitatore
i try that too
zonalimitatore
It's very hard for me know why doesn't work....I try 2 way (that posted here and thinkiverse),and both not work.
3dtouch dont give me response.
There is someone here that have a 3dtouch working on a10 rev B version 1 ?
zonalimitatore
A stupid question.Have i to set pin 11/13 (servo) for work?
When u are in endsop debug mode and manually pull up&down the probe,what's appening?
Repetier give u the state of pin?
zonalimitatore
can you try with gcode sender?
Cause,if my sensor it's defected i send back
zonalimitatore wrote: Sun Dec 16, 2018 9:33 pm I try to wire like in photo above.
When start the printer,the 3d touch do up&down 2 times ,and stay up with red led on.
The problem is:
I have no control on it
In the menu if i click autotest,no moves,and the same on other commands
I try to do z home,but doesn't stop,and signed my bed :evil:
It's my problem or anyone have solve it?
Could you attach the wires of the 3dtouch?
zonalimitatore wrote: Tue Dec 18, 2018 7:17 am A stupid question.Have i to set pin 11/13 (servo) for work?
You can join the facebook group.
You can refer to the pdf for GT2560VB work with 3dtouch
https://www.facebook.com/groups/315127105604393
jadonsancho
Post by jadonsancho »
vert wrote: Tue Dec 18, 2018 6:30 am
zonalimitatore wrote: Tue Dec 18, 2018 6:29 am i try that too
this is hard as i do not have anything to physically work with doing everything by latest kickass proxy unblocked.
i cant exactly bust out a multimeter and back trace the pins or anything.
thanksss
