Can't print a thing
diler35
Re: Can't print a thing
Post by diler35 »
I've recived new extractor today with a nice PLA filament as a gift, it's very kind.
I've just finished mounting new extractor and with a great hope i just run a gcode to print an example, but it's worst then the last time, it just doesn't works, pla keeps melting in extractor!!!
What a loss of money and time with this product.
After a few test i just take the pla back off the extractor, this is how its look like.
diler35
Post by diler35 »
Ofcourse it goes all the way down.
diler35
Post by diler35 »
This little mark comes from extractor, i push it down untill it stops.
diler35
Post by diler35 »
I don't know, i bought this printer on 10/10/2018 since than i couldn't print a thing.More than one month of trying every possibilities to make this printer work correctly, nothing to do!!! im just fed-up with this thing.
diler35
Post by diler35 »
I did this, all seems ok no reason that it doesn't work.All connections is ok, firmware updated but can't print with this printer i'll buy just anothe one but loosing 178€ piss me off!
diler35
Post by diler35 »
Yes i've contacted them, they send me a new extractor but it didn't change a thing.
I didn't check the vrefs, but im so fed-up with this thing that i'll just sell it as spare parts.
:mrgreen:
Photography thoroughly reveals the problem of clogging.
The PTFE tube must be inserted so deep that it rests on the bottom of the duct.
You have to give attention to two things:
  • that the duct for the PTFE tube is not dirty at the end
  • that the tube does not slip out of the handle.
Otherwise it will become congested. It will not be possible to move the filament.
Admittedly, what the vert says, you have to be perceptive and strive to solve problems. Maybe you have just started your adventure and you need to learn a lot about this machine.
Complainting is not helpful.
diler35
Post by diler35 »
This the longest PTFE tube goes into extractor, i can't push it any further.
andileibi@web.de
Post by andileibi@web.de »
Hello, I had the same troubles, try to print with higher nozzle temperature. My one is working well now but only with a nozzle temperature of 230°C for PLA
diler35
Post by diler35 »
I'll try to do that, maybe higher temperature make this thing work.
Thanks.
