Hello!
I tried to install the firmware for my new I3 Aluminium but in the folder "sanguino" is no neccesary *.ino file like in the description viewtopic.php?f=13&t=17181
Can u help me?
thx
Can u help me?
thx
Hi all, i finished to mount my i3 pro b printer black after lot of time. i want to upgrade the firmware to start, if i understund i should use this one
5) Firmware for I3 pro&proB
I3 pro&proB(GT2560)
Marlin-PI3_Pro_B.zip
(299.2 KiB) Downloaded 31929 times
Now, i am not sure about which guide i should follow. it has usb port, on windos
I3 pro&proB(GT2560)
I have i3 b pro printer. I'm trying to put the firmware "Marlin-PI3_Pro_B.zip" on it, but Adruino gives an error:"using typedef-name 'fpos_t' after 'struct'". How can I fix this?
Based on this excellent work above I modified Release 1.1.9 (The latest and probably last 1.1.x) of Marlin FW. It is in this repository/branch:JLa wrote: Thu May 18, 2017 8:56 pmMadScientist wrote:I have edited latest Marlin-RC8 1.1.0 firmware to fit it in MeCreator 2 and GT2560 Rev.B board. Feel free to try it, but remember it is a release candidate – use with caution! I used Arduino 1.8.1.
I appreciate your feedback.
Hi MadScientist,
Updatated To Marlin 1.1.1 with this file.
#define DEFAULT_AXIS_STEPS_PER_UNIT { 80, 80, 400, 93 }
#define DEFAULT_MAX_FEEDRATE { 300, 300, 20, 25 }
#define DEFAULT_MAX_ACCELERATION { 1000, 1000, 100, 10000 }
#define DEFAULT_ACCELERATION 300 // X, Y, Z and E acceleration for printing moves
#define DEFAULT_RETRACT_ACCELERATION 3000 // E acceleration for retracts
#define DEFAULT_TRAVEL_ACCELERATION 1000 // X, Y, Z acceleration for travel (non printing) moves
#define DEFAULT_XJERK 4.0
#define DEFAULT_YJERK 2.0
#define DEFAULT_ZJERK 0.4
#define DEFAULT_EJERK 5.0
Marlin Firmware/1.1.x-MeCreator-2: https://github.com/MatthiasJobst/Marlin ... eCreator-2
It is tested on my machine. Nevertheless I still see some quirks
There is no huge improvement over the original firmware 1.0.4. Some Menu changes mostly from what I saw.
Compared to the adaptation above the light can be switched on an off.
You can use git to track my changes to the original version or fork your own repository.
Re:Geeetech A10 with GT2560VB board firmware
new posted firmware Geeetech A10 with GT2560VB board has problems, x e steps and y have been changed from 80 to 80.3 and 80.8.
Also when auto home x and y go to home then vibrate and you have to power off the printer.
Had to flash a diffrent firmware to get the printer to work.
Tony
Tony
Re firmware A10_Marlin_VB 1.1.18
I have now sorted out the problems that I had after loading this firmare onto my A10 that has the GT2560 Ver B.
The pin numbers in the pins_GT2560_VB.h are incorrect and need to follow those in pins_ULTIMAKE.h. You also have to change the direction of the extruder from false to true.
Tony
Tony
3D Make ES
Problem A10
I have a problem with the A10, I have mounted it and I give it to print the gcode file of the card, but when I should start printing happens what you see in the video, could you help me? https://youtu.be/R0Zw8PBNtDM ,I tried to change the firmware for the one they have on their Github website but the problem continues, when I do a homing it does it without problems, but when it goes to print the Z axis goes down to force the motor, it can be heard in the video, I quickly unplug the printer so as not to cause damage to it, I have checked all the wiring and it is ok, also if it was not right I would not do the homing, I tried with other gcodes and do the same, it seems that the motherboard has some problem, I hope that can give me a solution, greetings
3D Make ES
I do not understand why you send me this link, what do you want me to do with it, this is a solution or what is it
salve a tutti sono nuovo del forum e delle stampanti 3d ho un piccolo problema sul asse z, iniziamo a dire che ho una I3 pro W assemblata da me ho scaricato il firmware e installato con arduino 1.0.6 ma avendo le barre filettate 8 dovrei lanciare il Gcode M92 Z400 e poi .500 per salvare ma non ho idea da dove iniziare per reperire questi Gcode e come installarli nella stampante
il problema è l'altezza dell'asse z che si alza troppo e non rispetta i MM correti
mi dareste gentilmente una mano che sto impazzendo da una settimana in rete non c'è una guida chiara su cosa fare
GRAZIEEEEEE
GRAZIEEEEEE
