Is it possible to get the *.hex file of the initial Firmware release the Acrylic i3 pro b https://www.geeetech.com/acrylic-geeete ... p-917.html with LCD2004 and GT2560 Rev A+ Board is shipped with?
@William
thank you for the fast reply.
In the about field of my Printer, the following information ist displayed:
Pi3 Pro B
Ver: 1.0.05
On the Download Site I can find only Ver: 1.0.04.
Is it possible to get the Ver: 1.0.5 *.hex file?
Pi3 Pro B
Ver: 1.0.05
surfersteve1
I have the Prusa i3 Pro W (Wood frame) with the newer T8 Threaded Rod Lead Screws and GT2560 Control Board. Which FW do I download and install? I see a few listed for different Prusa i3 Pro models but not the "W" version. There is also one "W" model listed but it only says "Pro W" and doesnt say Prusa or i3.
Follow the model designation "W". Prusa I3 is a distinguishing mark of the series to which your printer belongs. Pro W or W refers to one model.
Some names are abbreviated.surfersteve1 wrote: Thu Jan 10, 2019 3:59 am I have the Prusa i3 Pro W (Wood frame) with the newer T8 Threaded Rod Lead Screws and GT2560 Control Board. Which FW do I download and install? I see a few listed for different Prusa i3 Pro models but not the "W" version. There is also one "W" model listed but it only says "Pro W" and doesnt say Prusa or i3.
Hi there.
I have a really weird error (at least I think so) on my Mecreator 2, that I suspect is connected to a firmware issue.
I had a runaway temp on the nozzle a while back and melted a bunch of stuff. I replaced what was needed, re flashed it and tried printing.
Runaway temp once again.
The thing is that everything works fine up to 79c on the nozzle. As soon as I go above that it starts to get more and more inaccurate. For instance if I set it to 100c, it ends up at between 177c and 185c. It's not constantly ending up at exactly the same temp, it differs up to about 10c.
I replaced the thermistor again, but no improvement. Does anyone have any idea how to solve this?
*Edit*
It actually does trickle down to the correct temp eventually, but that means that if I for example want to print PLA at 200c, it simply gets way to hot before it eventually can settle at the correct temp
I guess this also happens when it tries to correct the temp mid print and that's what triggered the runaway temp the first time.
*Edit*
Hey all, just received the A10, don't know if the firmware is updated and I saw there are two different 2560 boards. How do I know which one to DL?
Can anyone help me out with this, I try and load FW update and Arduino comes u with this
Code: Select all
enabled in File > Preferences.
Arduino: 1.0.6 (Mac OS X), Board: "Arduino Mega 2560 or Mega ADK"
In file included from MarlinConfig.h:40,
from Marlin.h:36,
from planner_bezier.cpp:30:
SanityCheck.h:36:4: error: #error "Marlin requires C++11 support (gcc >= 4.7, Arduino IDE >= 1.6.8). Please upgrade your toolchain."
from Marlin.h:36,
SanityCheck.h:296: error: expected constructor, destructor, or type conversion before '(' token
SanityCheck.h:579: error: expected constructor, destructor, or type conversion before '(' token
SanityCheck.h:638: error: expected constructor, destructor, or type conversion before '(' token
SanityCheck.h:750: error: expected constructor, destructor, or type conversion before '(' token
SanityCheck.h:1312: error: expected constructor, destructor, or type conversion before '(' token
SanityCheck.h:1517: error: expected constructor, destructor, or type conversion before 'float'
SanityCheck.h:1517: error: expected unqualified-id before ',' token
SanityCheck.h:1518: error: expected constructor, destructor, or type conversion before '=' token
SanityCheck.h:1518: error: expected unqualified-id before ',' token
SanityCheck.h:1519: error: expected constructor, destructor, or type conversion before '=' token
SanityCheck.h:1520: error: expected constructor, destructor, or type conversion before '(' token
SanityCheck.h:1521: error: expected constructor, destructor, or type conversion before '(' token
SanityCheck.h:1522: error: expected constructor, destructor, or type conversion before '(' token
SanityCheck.h:1523: error: expected constructor, destructor, or type conversion before '(' token
SanityCheck.h:1524: error: expected constructor, destructor, or type conversion before '(' token
SanityCheck.h:1525: error: expected constructor, destructor, or type conversion before '(' token
In file included from planner_bezier.cpp:30:
Marlin.h:543: error: use of enum 'RecState' without previous declaration
Marlin.h:543: error: expected unqualified-id before ':' token
Marlin.h:555: error: 'RecState' does not name a typeRe: Firmware for geeetech 3D printers
I have use Firmware for I3 Pro C A+ with 3DTouch but dont work.
When I use G28 code extruders goes out of bed
Maybe you can attach the video link.
We will help to check it.
