I've checked your info again.
Here:
The motherboard won't work until you plug the USB cable.
Then I think the board seems can't get the power from the PSU.
You should check the PSU output +motherboard fuse.
iherbak
Post by iherbak »
Hi all,
I've downloaded the firmware for Gt2560 rev b, but there are no separated config files for 3d touch.
Is it on purpose?
joe88
Post by joe88 »
is there an official newer version for the i3 Pro W coming?
i would need the bilinear autobed leveling.
Regards
joe88 wrote: Sat Mar 16, 2019 12:13 am Hi,
Regards
The prob use the same hot bed,motherboard and hotend (Refer to the PROW)
It means you can upload the fw of prob.
viewtopic.php?f=20&t=60826 ;)
screwugr
Post by screwugr »
Hello guys !
im having trouble to find the right firmware for my Geeetech M201 Mixcolor 3D printer with GTM32 PRO VB board .can anyone help please?
Hello screwugr.
Our printer model has its own subforum, start reading them there is everything explained.
The latest firmware version for M201 is 1.0.03 (GTM32Pro vB).
Mad Monkey
Post by Mad Monkey »
I have a brandnew i3 Pro W that i have built
i attempted to print using sd card and it just says none installed, tried via USB and it didnt respond, all signs pointed to updating firmware..
i hooked the pc up to printer, downloaded the Prow firmware from this forum. and ardino 1.01.
verified the sketch and it verifies (baord 2560 com3)
when i click upload it loads 80% of the way and just hangs out.. no error, i left it for over an hr same result.
when i uplugged it i now have a blank screen on my LCD..
please advise what software and firmware files i ACTUALLY need.
Eclipses
Post by Eclipses »
can someone please explain me exactly to what kind of machine does the firmware "PI3A Pro(for the upgraded kit using lead screw).zip" refer to? I bought a PI3A Pro and it has lead screw as default, was there a PI3A Ori without lead screw?
Hi.
:mrgreen:
The difference is due to the use of different types of screws for the Z axis. In the past, ordinary metric M8 screws were used, then trapezoidal threaded hauling screws, e.g. TR8x2.
calinb
Getech i3 pro C (Marlin 1.1.8 for all) Arduino IDE Warning (SOLVED)
Post by calinb »
I am interested in upgrading my Ultimaker UMO (purchased in 2012) by installing a new GT2560 A+ board (and a few other new features). If it works well, I plan to purchase a Getech i3 pro C too (so I will have both 1.7 mm and 2.85 mm filament printers :D ). I always run custom Marlin so I thought I'd try building the latest Getech i3 pro C (Marlin 1.1.8 for all) source code first. Here is the source code:
6) Firmware for I3 pro C
Update:
Fixed the endstop error(Default endstop logic status is the"false")
2019/2/27
Marlin 1.1.8 for proC with GT2560VA/A+/2.0
1.Inculde 3dtouch config and no 3dtouch cofing
2.Added the new menu for extruder+hotend
viewtopic.php?f=20&t=17046&p=27625#p27625
Sadly, Arduino 1.8.5 and 1.8.9 both produced warnings after I extracted the files from the .zip archive (and I do not like warnings that can be corrected). See the warnings below.
To eliminate all the redefinition warnings, I un-commented a conditional define in pins_GT2560_REV_A.h.
Change
Code: Select all
//#ifndef BOARD_NAME
   #define BOARD_NAME "GT2560 Rev.A"
//#endif
to
Code: Select all
#ifndef BOARD_NAME
#endif
and all of the following warnings vanish! :idea:
Code: Select all
In file included from sketch/pins_GT2560_REV_A_PLUS.h:29:0,
                 from sketch/pins.h:176,
                 from sketch/MarlinConfig.h:34,
                 from sketch/Marlin.h:36,
                 from sketch/Marlin_main.cpp:249:
sketch/pins_GT2560_REV_A.h:34:0: warning: "BOARD_NAME" redefined
In file included from sketch/pins.h:176:0,
sketch/pins_GT2560_REV_A_PLUS.h:27:0: note: this is the location of the previous definition
 #define BOARD_NAME "GT2560 Rev.A+"
                 from sketch/nozzle.cpp:23:
                 from sketch/SdVolume.cpp:29:
                 from /home/demo/3D_Printer/Marlin/Getech i3 pro C (Marlin 1.1.8 for all)/Marlin/Marlin.ino:31:
                 from sketch/MarlinSerial.cpp:35:
                 from sketch/Max7219_Debug_LEDs.cpp:54:
                 from sketch/G26_Mesh_Validation_Tool.cpp:27:
                 from sketch/dac_mcp4728.h:30,
                 from sketch/dac_mcp4728.cpp:33:
                 from sketch/I2CPositionEncoder.cpp:31:
                 from sketch/Sd2Card.cpp:29:
                 from sketch/digipot_mcp4451.cpp:23:
                 from sketch/hex_print_routines.cpp:22:
                 from sketch/endstops.cpp:27:
                 from sketch/printcounter.cpp:23:
                 from sketch/serial.h:26,
                 from sketch/serial.cpp:23:
                 from sketch/digipot_mcp4018.cpp:23:
                 from sketch/leds.cpp:27:
                 from sketch/planner_bezier.cpp:30:
                 from sketch/least_squares_fit.cpp:35:
                 from sketch/servo.cpp:53:
                 from sketch/M100_Free_Mem_Chk.cpp:51:
                 from sketch/SdBaseFile.cpp:30:
                 from sketch/SdFile.cpp:29:
                 from sketch/SdFatUtil.cpp:29:
                 from sketch/enum.h:26,
                 from sketch/gcode.h:32,
                 from sketch/gcode.cpp:27:
                 from sketch/planner.cpp:61:
                 from sketch/stepper.cpp:47:
                 from sketch/stopwatch.cpp:23:
                 from sketch/ubl_motion.cpp:22:
                 from sketch/stepper_indirection.h:47,
                 from sketch/stepper_indirection.cpp:34:
                 from sketch/neopixel.cpp:27:
                 from sketch/pca9632.cpp:28:
                 from sketch/stepper_dac.cpp:44:
                 from sketch/blinkm.cpp:27:
                 from sketch/cardreader.cpp:23:
                 from sketch/mesh_bed_leveling.h:23,
                 from sketch/mesh_bed_leveling.cpp:23:
                 from sketch/ubl_G29.cpp:23:
                 from sketch/temperature.cpp:27:
                 from sketch/twibus.cpp:23:
                 from sketch/configuration_store.h:26,
                 from sketch/configuration_store.cpp:190:
                 from sketch/utility.cpp:23:
                 from sketch/ultralcd.cpp:23:
                 from sketch/ubl.cpp:23:
                 from sketch/watchdog.cpp:23:
                 from sketch/vector_3.cpp:42:
Locked
