Re: firmware for geeeteh 3D printers
Don't use the latest arduino version, usually the latest one will cause this problem, it's not the firmware's problem, try to use arduino1.0.1 or arduino 1.5.2.
Just a small question:
Is the configuration on the provided firmware allreday fitted to the printers?
I ask because Y-Max is set to 210. But when I move the YAxis to 210 the bed stops moving bevore the 210. 200 is fine.
you can set it to 200, or leave it as default if it won't collision with the frame.
frischbrot
dear geeetech-support,
i have this printer: http://www.geeetech.com/unassembledgeee ... rrrmhpfeq3
i assume that the firmware i need to dl is i3_pro_x.zip, but the downloads is not there anymore. could you reupload it?
you can find the one for your I3X on the first page of this post, right after the firmware for the I3 M201.
adnanaljeiroudi
I have "Prusa i3 X" and accedently I burned the socket for the heat bed.
I would like to use the other unused heating port (supposed to be for extruder 2).
i need help switching the heat bad port with the unused second extruder port.
can I do that via the firmware?
thank you !
thank you !
Hi all!
Is there a way to have an updated version of Marlin?
I've a I3X and I'd like to update my Marlin to the latest version!
Thz!
Thz!
Hi,Ferberto wrote:Hi all!
Thz!
If you have upgrade your I3X to a dual extruder,there is a new firmware.
Thz William.
I noticed that both versions (single and dual extruder) are based on Marlin 1.0.2-1.
Is it possible to update to Marlin 1.1.0-RC6?
Comparing the Marlin 1.0.2-1 with the I3X version, differences are minimal.
Thz!
Thz!
Hi,Ferberto wrote:Thz William.
Thz!
Sorry to tell you it is the latest version temporarily.
