Page 5 of 39
Re: firmware for geeeteh 3D printers
Posted: Tue Apr 12, 2016 5:35 pm
by Mark
Don't use the latest arduino version, usually the latest one will cause this problem, it's not the firmware's problem, try to use arduino1.0.1 or arduino 1.5.2.
Re: Firmware for geeetech 3D printers
Posted: Thu Apr 14, 2016 2:52 pm
by robvoi
Just a small question:
Is the configuration on the provided firmware allreday fitted to the printers?
I ask because Y-Max is set to 210. But when I move the YAxis to 210 the bed stops moving bevore the 210. 200 is fine.
Posted: Thu Apr 14, 2016 8:02 pm
by Mark
you can set it to 200, or leave it as default if it won't collision with the frame.
Posted: Thu Apr 28, 2016 1:23 pm
by frischbrot
dear geeetech-support,
i have this printer:
http://www.geeetech.com/unassembledgeee ... rrrmhpfeq3
i assume that the firmware i need to dl is i3_pro_x.zip, but the downloads is not there anymore. could you reupload it?
Posted: Thu Apr 28, 2016 3:38 pm
by Mark
you can find the one for your I3X on the first page of this post, right after the firmware for the I3 M201.
Posted: Tue May 03, 2016 5:30 pm
by adnanaljeiroudi
I have "Prusa i3 X" and accedently I burned the socket for the heat bed.
I would like to use the other unused heating port (supposed to be for extruder 2).
i need help switching the heat bad port with the unused second extruder port.
can I do that via the firmware?
thank you !
Posted: Mon Jul 04, 2016 9:47 pm
by Ferberto
Hi all!
Is there a way to have an updated version of Marlin?
I've a I3X and I'd like to update my Marlin to the latest version!
Thz!
Posted: Tue Jul 05, 2016 10:13 am
Ferberto wrote:Hi all!
Thz!
If you have upgrade your I3X to a dual extruder,there is a new firmware.
Posted: Tue Jul 05, 2016 7:12 pm
by Ferberto
Thz William.
I noticed that both versions (single and dual extruder) are based on Marlin 1.0.2-1.
Is it possible to update to Marlin 1.1.0-RC6?
Comparing the Marlin 1.0.2-1 with the I3X version, differences are minimal.
Thz!
Posted: Fri Jul 08, 2016 6:10 pm
Ferberto wrote:Thz William.
Thz!
Sorry to tell you it is the latest version temporarily.
