Locked
turbosnute
Post by turbosnute »
Is this the lates firmware version for the MeCreator 2? I updated my MeCreator 2 and now I miss menu options like "turn light on". So I have a feeling that the firmware in this forum post is older than the one my printer came with.
turbosnute wrote:Is this the lates firmware version for the MeCreator 2? I updated my MeCreator 2 and now I miss menu options like "turn light on". So I have a feeling that the firmware in this forum post is older than the one my printer came with.
Have a try to this one:
MeCreator2.zip
(284.34 KiB) Downloaded 1168 times
turbosnute
MeCreator2.zip
Thanks for a newer firmware, but I still can't seem to have the "light on" option in the menu :roll:
MeCreator2.zip
It's weird...Could you plz take some LCD pics about the corresponding menu?
In addition,did the menu appear the "light on" again when you reload the initial firmware?Or you didn't try that?
Regards
turbosnute
I have uploaded the firmware multiple times.
Here is snapshots from the menus:
main menu
main menu
Prepare menu
Prepare menu
turbosnute wrote:I have uploaded the firmware multiple times.
The attachment menu1.jpg is no longer available
The attachment menu2.jpg is no longer available
OK,but my printer's LCD switch is not in "Prepare" menu,it is in here:
Did you have a wrong place?
turbosnute
I forgot to take a photo of that menu, but I don't have anything beneath "Print from SD card"
turbosnute wrote:I forgot to take a photo of that menu, but I don't have anything beneath "Print from SD card"
Have a double check on it...
JohnQuix
Post by JohnQuix »
Is there a newer version of the MeCreator 2 firmware that doesn't get rid of the light control and doesn't print off center? The two that I have both print about 15 to 20mm to the left on the X-axis.
When I ask tech support they just tell me to download this version which definitely gets rid of the the light control.
So far it seems as if all versions print off center and I'm somewhat of a novice but I think it is because the printer thinks it has 175 on the X-axis.
Hi,my friend
Have you solved your problem?If not,try my new firmware for Mecreator2:
MeCreator2固件.zip
(293.54 KiB) Downloaded 1073 times
Locked
