How to install the firmware for GT2560
Locked
bang
Re: How to install the firmware for GT2560
Post by bang »
Congratulations :) @ kovac_00
TITI44
Post by TITI44 »
Je voulais modifier le sens des axes et je me suis trompé de firmware.
Je veux installer le bon et j'ai le message suivant :
In file included from sketch/SdFile.h:27:0,
from sketch/cardreader.h:8,
from sketch/Marlin_main.cpp:44:
struct fpos_t {
In file included from sketch/Marlin.h:10:0,
from sketch/Marlin_main.cpp:30:
/Users/thierryballester/Downloads/Arduino.app/Contents/Java/hardware/tools/avr/avr/include/stdio.h:950:33: note: 'fpos_t' has a previous declaration here
exit status 1
bang
Post by bang »
TITI44 wrote:Je voulais modifier le sens des axes et je me suis trompé de firmware.
struct fpos_t {
exit status 1
Download the right firmware for your printer from here:
viewtopic.php?f=20&t=17046
And remember to use Arduino 1.0.1 to upload it:
http://www.geeetech.com/wiki/images/a/a ... indows.zip
Mindzhius
Post by Mindzhius »
I bought a geeetech i3 pro b acrylic printer, I assembled it and tried to connect it to PC and failed. I did what user manual told to, but no luck. I tried to reflash firmware but no lock too. Arduino 1.0.1 throws me many errors after waiting for about 10 minutes. Can anyone help me?
firmware fail.png (237.01 KiB) Viewed 21631 times
JBJBJB82
Post by JBJBJB82 »
Hi, I have designed and built a core xy printer with the GT2560 Rev A+ board. Can I use a current Arduino version (1.8.1) to upload firmware or does I need to use Arduino v1.0.1?. What firmware can I use to customize, can I use a current Marlin version from Github (1.0.2-1) or does I need to use the one from Geeetech website (Marlin-Marlin v1)? Thank you in advance
bang
Post by bang »
JBJBJB82 wrote:Hi, I have designed and built a core xy printer with the GT2560 Rev A+ board. Can I use a current Arduino version (1.8.1) to upload firmware or does I need to use Arduino v1.0.1?. What firmware can I use to customize, can I use a current Marlin version from Github (1.0.2-1) or does I need to use the one from Geeetech website (Marlin-Marlin v1)? Thank you in advance
Maybe you can use the one from Github if you are gonna customize.
Stoned_Stew
Post by Stoned_Stew »
I am trying to setup my new i3 X printer and firmware.
I downloaded the I3_pro_X.zip from https://www.geeetech.com/forum/viewtopi ... 20&t=17046
I have not yet modified the script but only just tried to verify the script, however i get the following error message.
I really have no idea what im doing with this kind off stuff, except altering steps etc for setup/calibration as per instructions and youtube videos!
Can someone explain what i need to do to fix these issues please?
I have tried changing 'fpos_t' to 'fpost' as per a workaround i found but this seems to cause cascading errors as a result.
As i have no coding experience i am now stuck at a point where i need to modify the firmware to get the best from this printer!
Arduino: 1.8.1 (Windows 7), Board: "Arduino/Genuino Mega or Mega 2560, ATmega2560 (Mega 2560)"
from sketch\BlinkM.cpp:5:
#define X_MAX_PIN -1
#define X_MAX_PIN 24
#define Y_MAX_PIN -1
#define Y_MAX_PIN 28
sketch\pins.h:2958:0: warning: "Z_MAX_PIN" redefined
#define Z_MAX_PIN -1
sketch\pins.h:1375:0: note: this is the location of the previous definition
#define Z_MAX_PIN 32
from sketch\ConfigurationStore.cpp:1:
from sketch\thermistortables.h:4,
from sketch\Configuration.h:792,
from C:\Users\User\Downloads\3D Print software\I3_pro_X\I3_pro_X\Marlin\Marlin.ino:33:
from sketch\MarlinSerial.cpp:23:
sketch\Marlin_main.cpp:2667:36: warning: invalid suffix on literal; C++11 requires a space between literal and string macro [-Wliteral-suffix]
from sketch\cardreader.h:8,
struct fpos_t {
c:\program files (x86)\arduino\hardware\tools\avr\avr\include\stdio.h:950:33: note: 'fpos_t' has a previous declaration here
exit status 1
cRaZyT
Post by cRaZyT »
@Stoned_Stew,
your Arduino version(1.8.1) does not work with the downloaded firmware.
Try it with Arduino 1.0.1 that should work.
zurferjoe
Post by zurferjoe »
Hi Folks , newbie trying to get the Software installed ,nothing new to you people ! I have got the Arduino 1.0.1 Windows ,for Geeetch , downloaded I pull up the Arduino no problem , press Tools (takes forever ) Select port, select board ,starts downloading and goes from green to orange and black !! Ist telling e ist wrong ! But whats wrong ? Hope you can give me a clue ,
Jeroen
Post by Jeroen »
Hi,Can someone help me? I have a aluminum I3 sanguinololu printer and I follow the suggestions at this post and http://domoticx.com/prusa-i3-geeetech-f ... guinololu/.
But it is not working. By checking the sketch i get the error: getpos_t'has not been declared
And in yellow: void getpos(fpos_t* pos);
Locked
