SIM900 GSM / GPRS Shield UART voltage levels
burespe1
Post by burespe1 »
I would like to use SIM900 GSM / GPRS Shield with Raspberry Pi (RPi) and communicate over serial interface UART. Voltage level of UART on RPi 3.3 VDC.
Could I connect RPi directly to SIM900 GSM / GPRS Shield? (I found out that you support UART of SIM900 that has a 2.8 VDC logic and I guess that 5 VDC is implemented as well, may be also needed 3.3V?)
or do I have to use some voltage level converter? (like https://www.sparkfun.com/products/8745)
Thanks in advance
Petr
techsupport
Re: SIM900 GSM / GPRS Shield UART voltage levels
Post by techsupport »
Hi,friend
The SIM900 GSM / GPRS Shield is installed the voltage level converter,you can connect SIM900 GSM / GPRS Shield and Raspberry Pi (RPi) from serial interface UART directly .
Yours sincerely
techsupport
Email: forum@geeetech.com
justAq
Post by justAq »
Can you please explain furthermore on how to connect between the two?
Raspberry Pi's UART Pins: TX/RX (3.3V) & GND Should be connected to....(SW Serial ? /HW Serial ? /UART (2.8) ? ) ?
How to configure the jumpers for using with Raspberry Pi?
justAq
Post by justAq »
Any response? :roll:
treii28
Post by treii28 »
How do you get the uart to work? I tried connecting to the tx/rx/gnd using a 3.3v ftdi but couldn't seem to get a response out of an AT even with autobaud set. (I confirmed first the modem is working find with the arduino passthrough sketch)
