Printerboard doesn't enter boot mode
egarner
Post by egarner »
I'm not able to get the printrboard to enter bootloader mode so I can load firmware. I've attempted to follow the directions located at http://www.geeetech.com/wiki/index.php/Printerboard, but am still unsuccessful.
lsusb always indicates the device is VOTI whether I leave the boot jumper on or take it off.
what am i doing wrong?
techsupport
Re: Printerboard doesn't enter boot mode
Post by techsupport »
hi
guys
what is your OS ? win or MAC?
It is support windows perfect,there is some bug on mac and linux.
Email: forum@geeetech.com
egarner
Post by egarner »
I got it figured out, but needed to find the schematic in order to do it. First, to answer your question, I tried Ubuntu and Windows 7 on two separate Printrboard cards. Same results with both.
After checking the voltage on the reset switch pins, I found that the switch was not working. I attempted the reset by shorting the contacts with a screwdriver and viola!, boot mode.
Both cards appear to have inoperative reset switches. If you press down and wiggle the switch, it pulls the reset pin on the processor low but not apparently long enough to reset. A screwdriver across the switch terminals does the trick.
Ernie
techsupport
friend
Can you find com port in your device manager? if not ,maybe your key or board is bad.
