Pb with arduino GSM900 GPRS SHield
texouille
Post by texouille »
i bough this item a few days ago and i already received it. That is great.
The GSM shield do not register to any network.
I did put external +5V power supply 2A.
I can communicate with the modem and send AT commands.
The sim card is OK and PIN is OK I can read info from sim card.
Antenna seems to be well connected.
When i scan the network list, i can not see any network: AT+COPS=? +COPS: ,,(0,1,4),(0,2)
AT+CREG? +CREG: 0,0
My operator allow the use of sicard for any phone on any IMEI and i did test it on several opearator with several sim card. I am currently in france. So the shield does not seems to work properly. Can you help me. I already bough this kind of shield wihout any problem in the past.
Regards,
texouille
Re: Pb with arduino GSM900 GPRS SHield
Post by texouille »
Of course i already tried that.
When i try to make an ATD i do have No DIal tone
Anayway the blinking led is blinking every 800 ms and not every 3 seconds, so definitely it is not registred onto the network.
As i said before, i do tested this kind of shield before without any problem.
There is no network seen onto the shield when i scan the network.
For example with another gsm card that is working properly :
AT
OK
AT+CREG?
+CREG: 0,1
OK
AT+CSQ
+CSQ: 85,99
OK
AT+COPS=?
+COPS: (2,"F BOUYGTEL",,"20820",0),
(3,"Orange F",,"20801",0),
(1,"F SFR",,"20810",0),,(0,1,3),(0,2)
OK
I can see the networks, i do have a signal strengh.
With the "faulty" card, no network is seen, as if the antennas was not working (i checked it, it is well connected, and antennas is well inserted). I did put an external power supply (5V DC, 2 A) onto the shiled, i did put the switch to EXT as it is external power supply.
But no chance, that is definitely not working. I tend to thik the unit is faulty.
Regards
texouille
Post by texouille »
just to show you the result with the "faulty" shield
RDY
+CFUN: 1
+CPIN: READY
Call Ready
AT
OK
ATD0695588888
NO CARRIER
AT+COPS=?
OK
texouille
Post by texouille »
my results:
RDY
+CFUN: 1
+CPIN: READY
Call Ready
AT
OK
AT+COPS=?
OK
AT+CREG?
+CREG: 0,0
OK
CREG 0,0 means Registration in progress
in your example +CREG: 0,4 means: not registred
texouille
Post by texouille »
yep, it seems that everything is ok, but as if the shield is not able to catch any signal, as if there was an antenna problem unable to catch the GSM radiowave.
I had a look at the antenna connector and it seem all right as well.
I do not know what i can do by now.
Regards,
texouille
Post by texouille »
Sorry,
I lready tried that as well.
ATD0695588888;
NO DIALTONE
Regards
