I have a problem with the motors of thet prusa i3a, the motors do not move properly, when i send a file to print the printer does something completely different.
Do i need to update the firmware of the mega2560 + ramps 1.4?? or is this done by Geeetech?
When i read the eeprom it says marlin Sanguinololu Rev 1.3a??
Please help!
Geeetech Acrylic Prusa i3:motors do not move properly
Re: Geeetech Acrylic Prusa i3:motors do not move properly
Dear friend,
The firmware of printer has been burned, so we do not recommend reburning yourself. Because that does not necessarily help to solve your problems.
What mother board is on your machine? Can you decribe your trouble more detailedly, so that we can provide a better solution.
Best regards!
Best regards!
I bought the Prusa I3A and I have some problems. (Ramps1.4 + MEGA2560 + A4988 + LCD2004)
Firmware is loaded by default? If not, could you send the correct configured marlin please?
issue:
The engines do not respond or poorly. Manual control with repetier host is after 1 to 2 mm reporting printend stop. When I start a print engines works, but doing something completely different than print and they go outside the bed aswel and the Z axis dont move.
issue:
hi,
this is the log of the repetier host:
22:18:41.145 : start
22:18:41.145 : echo: External Reset
22:18:41.145 : Marlin 1.0.0
22:18:41.160 : echo: Last Updated: Jan 13 2015 10:18:58 | Author: (Eddie, Sanguino 1.3)
22:18:41.160 : Compiled: Jan 13 2015
22:18:41.160 : echo: Free Memory: 4057 PlannerBufferBytes: 1232
22:18:41.160 : echo:Hardcoded Default Settings Loaded
22:18:41.160 : echo:Steps per unit:
22:18:41.160 : echo: M92 X80.00 Y80.00 Z2560.00 E760.00
22:18:41.160 : echo:Maximum feedrates (mm/s):
22:18:41.176 : echo: M203 X400.00 Y400.00 Z2.00 E45.00
22:18:41.176 : echo:Maximum Acceleration (mm/s2):
22:18:41.176 : echo: M201 X5000 Y5000 Z50 E5000
22:18:41.176 : echo:Acceleration: S=acceleration, T=retract acceleration
22:18:41.176 : echo: M204 S1000.00 T2000.00
22:18:41.176 : echo:Advanced variables: S=Min feedrate (mm/s), T=Min travel feedrate (mm/s), B=minimum segment time (ms), X=maximum XY jerk (mm/s), Z=maximum Z jerk (mm/s), E=maximum E jerk (mm/s)
22:18:41.191 : echo: M205 S0.00 T0.00 B20000 X20.00 Z0.40 E5.00
22:18:41.191 : echo:Home offset (mm):
22:18:41.191 : echo: M206 X0.00 Y0.00 Z0.00
22:18:41.191 : echo:PID settings:
22:18:41.191 : echo: M301 P19.86 I1.00 D98.93
22:18:42.566 : echo:SD card ok
22:18:42.566 : echo:Unknown command: ""
22:18:42.613 : FIRMWARE_NAME:Marlin V1; Sprinter/grbl mashup for gen6 FIRMWARE_URL:http://www.mendel-parts.com PROTOCOL_VERSION:1.0 MACHINE_TYPE:Get Prusa I3A EXTRUDER_COUNT:1 UUID:00000000-0000-0000-0000-000000000000
22:18:44.838 : FIRMWARE_NAME:Marlin V1; Sprinter/grbl mashup for gen6 FIRMWARE_URL:http://www.mendel-parts.com PROTOCOL_VERSION:1.0 MACHINE_TYPE:Get Prusa I3A EXTRUDER_COUNT:1 UUID:00000000-0000-0000-0000-000000000000
attachment foto's setting marlin
- repetier info.zip
- (102.44 KiB) Downloaded 817 times
Dear friend,
The firmware of machine has been burned, please try the following methods to solve your problem:
1. Replace a USB wire
2. Check whether the connection of Z-axis motor is normal
3. Swap the A4988 module of X or Y axis and the A4988 module of Z-axis, then check whether Z-axis is in working order
4. Check whether the jumper caps of X,Y and Z axis motor have been plugged.
5. Please check if X,Y and Z axes can move manually on Repetier Host. Check if every axis can return to zero and has a correct moving direction
Best regards!
Best regards!
Thanx the printer is working, jumpersettings where not good
