Extruder stepper motor make noise and doesn't work properly
digitmakers
Post by digitmakers »
The extruder Stepper Motor makes noise, doesn't rotate and vibrate in the middle of print job As a result the filament is not flowing .
Please help
harry_chen
Re: Extruder stepper motor make noise and doesn't work prope
Post by harry_chen »
Hi digitmakers
You can check if the nozzle's temperature is too low so that the felament didn't melt,
or the diver gear is too tight and trapped with the wheel, just take apart the fan and fix it.
harry_chen
Have watched. Is the motor too hot to run?
There is no heat sink and cooling fan on the motor.
digitmakers
The motor is not hot . The fan placed on the back of the extruder for the me creator model. Please list possible root causes to the problem and I will verify one by one.
harry_chen
It seems like the extruder motor run too fast, and too much filament came out.
So you can set the esteps in the LCD screen: Control -> Motion -> Esteps
Set it to 95~100, was it much larger than 100 before?
Or you can tighten a little the screw.
digitmakers
Harry ,
After many diagnosis I found the problem it was bad wiring connection to the extruder that make the extruder stepper acting the way shown in the video , after taking the cable wire off the printer and fixing the connection , the printer is working properly .
thanks
digitmakers
If the wiring is ok you will need to adjust the stepper motor controller rheostat to above 1.2 volts .
harvester66
Post by harvester66 »
Hi Digitmakers.
I have the same issue. Can you tell me how you fixed the wiring to the extruder?
Aloneguy
Post by Aloneguy »
I have same problem too,
