MIN TEMP err on start up
cds5104
Post by cds5104 »
I am getting a MIN TEMP error for the nozzle on start, I have checked the connection to the ramp board (swapped it with the hot bed, changed the connector orientation, etc ), unplugged, and shorted the pins using a jumper, it always reads MIN TEMP. When I read the voltage at the thermistor it is at 4.75 VDC across it. At this point I am stuck wondering if I am stuck with a defective Ramp and asking for help on this one. I purchased the kit on Feb 1, and the is Receipt No: 5280-3488-4229-7650.
Thank you
john
Re: MIN TEMP err on start up
Post by john »
Can you heat the nozzle when connect it in hotbed header? We want to know what was broken? Or the thermistor might short with nozzle?
We will send you a replacement when we make sure what the problem is.
cds5104
Post by cds5104 »
I figured the MIN TEMP out, the thermistor connection, it is reading it off of T2 instead of T0. However I have another issue, I am getting end stop errors, specifically "echo: endstops hit" on every axis despite being centered. I also have no home position movement.
john
Post by john »
Could you please tell me what board you are using, or send your purchase link to me?
It looks like you set a wrong endstop electrical level, you can change it by software or hardware.
If search X_MIN_ENDSTOP_INVERTING, you would find the place where set the endstop electrical level. But firstly, you have to confirm you are ready to re-upload firmware.
I still need the list what you had bought from us so that we can give you support better.
john
cds5104
Post by cds5104 »
As far as board, it is using a Ramps 1.4, and in terms of setting anything in the firmware, up to this point I have not touched anything in the firmware. I am about to look into it, and if this is running just an arduino mega type of board then yes I am ready to upload firm ware.
john
Post by john »
You just need to modify configuration.h file, relative configurations are all put in it.
And also you can search how to modify a Marlin firmware for 3D printer, you may get a lot of answers.
cds5104
Post by cds5104 »
Can you PM the original configuration file, I was getting somewhere with it, got rid of the MIN temp, and end stop problems, but now I turned it on this morning and it isnt executing any commands. It connects, I am able to upload to it, but it does not execute any manual movements or g code scripts.
cds5104
Post by cds5104 »
Can I have the original configuration file emailed to me, the system is now not responding to the application. I got reading from the extruder, and completed a dry run print, however when I went to start a print on Saturday morning the system would not respond to the application. It connects, I am able to upload firmware to it, but the commands just stack and don't execute any movements or g codes.
Admin
Post by Admin »
Here is the firmware of ramps1.4
ramps14 firmware.rar
(229.24 KiB) Downloaded 532 times
