Prusa I3 : fan speed
Posted: Mon Feb 23, 2015 1:46 am
by carmelo42
Hello
Is it possible to modify the fan speed with repetier ? or in the gcode file ?
My 2 fans (extruder and electronic board) are 100% all the time ...
Thanks !
Re: Prusa I3 : fan speed
Posted: Mon Feb 23, 2015 11:30 am
by john
We can set the fan always running or not in gcode, and you can make the gcode in RepetierHost\slicr\configuration\filament settings\cooling, but it also needs boards support.
I don't know what board your are using, as I know, Ramps1.4 and Sanguinololu cannot support auto cooling fan.
Posted: Sun Mar 15, 2015 4:03 pm
by carmelo42
Hello John,
thanks for your answer.
I have Sanguinololu. I'm using Repetier and Slic3r.
So can I reduce the fan speed ?
Posted: Mon Mar 16, 2015 9:10 am
by zhangxueyou
Sorry, you can't control its speed, because in the circuit, there is only power supply and GND at 2 sides of the fan, without anyother controlling component. That means you can only have the fan run or not.
