Also no motors moving
jhoarty
Post by jhoarty »
I get heat on the heatbed and hot end, and lights blinking on the controller board when I send a print, but no motors are moving at all. Also, there is no display on my LCD screen. I just finished building the Prusa i3 and I am trying to make it work.
zhangxueyou
Re: Also no motors moving
Post by zhangxueyou »
Hi, please leave your email address, I will send the correct firmware to your email, and teach you how to burn the firmware. I am sorry because some of the printers were burned with the older version firmware.
As for the LCD screen, if the screen is glowing but displaying nothing, maybe the contrast is not high enough:
Please look at the backside of the screen, there is a little screw on the top-right corner. Rotate the screw a bit.
jhoarty
Post by jhoarty »
Hi, I would love to have the firmware sent to jhoarty@gmail.com. Thanks. Anyway, I figured out how to do it myself and was able to print yesterday. I downloaded Marlin and successfully edited the Configuration.h file. That solved everything - the LCD screen, the motors, everything. Thanks!
