Err: MINTEMP LCD and Repetier-Host
My LCD reads Err: MINTEMP and once connected Repetier-Host shows this:
Error:0
Extruder switched off. MINTEMP triggered !
Error:Printer stopped due to errors. Fix the error and use M999 to restart. (Temperature is reset. Set it after restarting)
Error:0
zhangxueyou
Re: Err: MINTEMP LCD and Repetier-Host
Please wait a minute.
zhangxueyou
Please short the 2 pins on mainboard for connecting thermistor. See if there is any difference displayed on LCD.
There was no difference. it is reading 26/0 26/0 and the error stays there
If I short it and remove then short again the left side number changes as such:
26/0, 47/0, 120/0, 8/0
Both sets of Thermistors do this
zhangxueyou
Turn off the printer and turn it on again, see if there is any diferrence.
Turned it off and on three times all three times the LCD read;
31/0 26/0
Err: MINTEMP
31/0 26/0
Err: MINTEMP
I found if I turn it off and unplug the USB as well then plug it back in the temps change a bit each time. Sometimes higher sometimes lower.
So what should I do now? How do I fix this?
zhangxueyou
Please upload a picture of mainboard in this page. I want to check your wiring.
