LCD showing blocks after RAMPS flash. Nothing works anymore
Posted: Sat Mar 28, 2015 1:14 pm
by Civiking84
Blocks
Blocks
As the title says. I recently flashed the board, and now nothing works. Before the flash, I could home the axis but not adjust any other direction in Repetier host. Now I can do nothing. And the screen looks like this when powered on
Re: LCD showing blocks after RAMPS flash. Nothing works any
Posted: Sat Mar 28, 2015 2:08 pm
by zhangxueyou
Did you change anything of the firmware? Or Did you change something in a file by accident?
Posted: Tue Mar 31, 2015 3:07 am
by Civiking84
Nothing was changed. I tried multiple times re flashing the board and it still does the same thing. I used the file I was sent and all 63 items went to it. It still connects in Repetier but I cannot control anything. It says 2 movements pending.
Posted: Wed Apr 01, 2015 9:36 am
by john
Did your LCD display right before, even once? How about it when you first used it? We need to confirm it's a software or a hardware issue.
Posted: Wed Apr 01, 2015 10:09 am
by Civiking84
Yes it worked. And I could home the axis. Now the screen shows that and nothing else works. I've requested a refund already. I purchased a different brand that I have received and it is working.
