JIETAI GT9S Extruder
Igor
Post by Igor »
Hi.
Need to replace stainless steel extruder pipe screw (inner diameter 2 mm), where I can buy it ?
Melvin
Re: JIETAI GT9S Extruder
Post by Melvin »
How you got this thing to work anyway?
I bought one, and if I heat it up, it reaches 110 degrees with and 150 degrees max without the lower cooling fan. It seems like the fan mount is getting so hot that the nozzle can`t heat proper.
