Problem to connect to Repetier
hiram.uribe
Post by hiram.uribe »
Hi, i have some problems.
1. When i connect the ME Creator to Repertier i found the port and made the connection, but i cant see the temperatures and i can not move anything.
2. Where I connect de Screen? I need to change de firmware?
3. Can you mail me the firmware to hiram.uribe@hotmail.com?
4. Can I use Marlin firmware?
john
Re: Problem to connect to Repetier
Post by john »
You don't need to re-upload a firmware, we had uploaded a Marlin firmware for your machine.
Can you home all axis when clicking on HOME button?
Visit the wiki page for your motherboard and it will show you how to connect a LCD screen.
hiram.uribe
No, when i select home all the printer dont move.
zhangxueyou
Post by zhangxueyou »
Can you control the motors on LCD screen?
hiram.uribe
How connect the LCD?
I connect tthe LCD in the Card but i dont see anything, is there some manual about how to connect de LCD? I need change the firmware?
zhangxueyou
No, as you turn the printer on, the LCD is on too.
So please tell me, how is the LCD? Is it dark, or just glowing without displaying anything?
hiram.uribe
Is glowing without displaying anything
zhangxueyou
Please rotate the little screw above SD card on the back side of LCD, check if there is any change.
hiram.uribe
LCD is glowing just few seconds, then turn off . What can i do?
zhangxueyou
When you connect your printer to computer, you should turn on the printer. Computer provides only 5V voltage.
